Question about Canon Office Equipment & Supplies
Canon iR3235 will not print over the network. I can ping
IR3235 will not print over the network. I can ping it and access the Web UI, but cannot get it to print. I have tried a variety of drivers from the Canon website, including PCL6 and the UFRII driver. When I print to it, the job will clear the print queue and go to the printer. The printer will display something in the log under network that says ''NG'' for the result and it shows from my IP address.
Any ideas at all?
  • 4 more comments
  • Rodrigo Brasileiro Jan 05, 2012
    I'm looking for a solution for the same issue. Did you fix yours?
  • Eduardo Ferrari
    Eduardo Ferrari Feb 22, 2012
    Me too, I had the same issue on my office yesterday. Did you found a fix?
  • philip May 10, 2013
    1. reinstall printer driver / According to the specifications 32bit/64bit 2. you have to windows update all 3. restart spool service
    if you see fail screen? you check windows log event about printer error message. and write here
    i wondering this problem . how resolve it. i have same problem...now.. plz let me know...
    i use to windows 7/32bit and office 2010 .. my printer information is cannon IR 3235 / IR 3245 UFR II . my printer don't work on excel and pdf files.
  • 22 Answers
Check if UFR II Kit was installed. If it is installed, try connecting the printer using peer-to-peer. Connect your PC directly to the printer using cross cable. Then try printing. If printing normally, reconnect to your network and change the IP address.
Posted on Oct 07, 2014
  • 56 Answers
Reboot the printer. ANd also try re-mapping the printer from your system.
Posted on Jul 09, 2010
  • dlloyd872 Jul 09, 2010
    I actually rebooted already and have remapped from my system and from other systems.
I cannot figure out how to get this printer (Canon imageRUNNER 3235) to join a wifi network so we can wirelessly print from multiple computers.
Is this a wireless device? According to the Canon specs it's wired LAN only http://www.canon.co.uk/For_Work/Products/Office_Print_Copy_Solutions/Office_Black_White/iR3235/index.asp?specs=1 You could either use a wireless bridge to connect it to your wireless network or hard wire it to your switch/router by a CAT5 cable
Jan 08, 2013 | Office Equipment & Supplies
Has network card which i can ping to but fails to
Have you installed the printer driver. If not install but do NOT plug printer in till it tells you to.
Mar 05, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Printer can not ping
is this is a print server/network printer? first off, the basics --- is the computer you are using to ping the printer on the same LAN IP as the printer (e.g. 192.168.1.x for both)? is this a wireless print server/network printer? if yes, physically connect it first to a router or switch and check if you can ping it. if you can, does it have a web interface, make sure you can access it and its wireless settings matches those of your wireless router.
Post back whatever you can come up with so I can give you more specifics
Jul 13, 2009 | Zebra (11X-7CX-XXXXX) (11X7CXXXXXX) Print...
NBX 3000: Can't access WEB UI or Ping - System still up.
There is most likely another device on the network with the same IP as the phone system. You can check this by un plugging the link to the phone system (after hours of course) and then pinging the IP of the phone system. If you get a reply while the link is disconnected then you know there is a duplicate IP on the network. You can use your server to try to identify the device or use a IP scanner like NetScanTools to ID it. You could also try changing the IP address of the phone system and see if you have the same problem.
Apr 17, 2009 | 3Com NBX V3000 IP Phone
RemoteUI Contents is Not Found
Remote UI probably has not been installed on copier. Get a technician to come out and use SST to load RUI onto your copier. They should upgrade firmware to latest version at same time.
Don't forget you can also pull scan over the network using Canon Network ScanGear Tool in case you would like to scan.
Oct 18, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Can't print over network
make sure you have an ip address on the printer and that the lan speed is correct, from a command prompt you should be able to ping the printer.
>>>ping <ipaddress of printer>
Aug 14, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Firmware problems
Check if you can still connect to the the camera's UI, connect it to a router or computer. Try to ping its IP address and access the camera's UI, if ur able to access it, try to do the firmware upgrade again.
Mar 07, 2008 | Linksys Wireless-G WVC54G Network Camera
1,624 people viewed this question
old marine
old marine
