Question about Gateway FPD2275W LCD Monitor
Monitor failure my two year old monitor has no amber light, does it have an internal fuse and if so how do i open it victor
  • Anonymous Aug 09, 2008
    Power light comes on red, then disappears. No picture anymore. Used in autoparts store since new
  • 180 Answers
If there are 4 srews. unscrew the screws and lift the bottom first them first then the top.
Posted on Apr 19, 2008
Amber light contineu glow
The amber light verifies your monitor is connected to primary power. The internal power supply is dead, otherwise the amber light would change color when the switch was operated.
Sep 02, 2012 | Acer AL1916W 19" LCD Monitor
17 inch E171FP monitor (Dell) - Snaps on for a few seconds then goes into sleep mode (amber light). You can reboot and the same thing happens over and over. Always has a picture, then goes to an amber...
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Aug 29, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
After changing old model monitor for Samsung SyncMaster 740N 17'' inch model monitor it doesn't display at all, only amber light dims intermittent.
First, try it on another PC first.
Second, the video resolution of your PC should be set to 1280 x 1024 @60Hertz.
Unless it has problem inside, then you will need to open it up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Aug 20, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
The monitor has no picture at all and the light goes from green to yellow
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 20, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
Cant get monitor to turn on
Try it on another PC nad also try new or check the VGA cable first, if it still doea not work and you want to DIY repair, then please read below and look at pictures albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 13, 2010 | HP Pavilion F1523 15" LCD Monitor
Acer v193w monitor screen is black, and an amber light is flashing. How do is fix it?
The blinking Amber light can mean two things, one is that the monitor is not getting the video signal from your PC, or it can be problem in the monitor power supply due to bad caps. Please try it on another PC first before opening up the monitor. If is it the monitor then read below so you can make up your mind if you want to DIY or not.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 14, 2010 | Acer V193w LCD Monitor
The monitor shows a black screen but the green
Yes, there is internal main AC fuse, which should be OK because you can see the indicator light, you need to open it up and check for caps with bulging tops first, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 07, 2010 | Acer AL1714CB (Black) 17" LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
All dead except for flashing amber light.
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
