Question about John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers
I have a john deere stx38, has no spark. Engine turns over fine but will not fire. JW
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Check the HT lead for cuts or breaks and then replace it anyway then check the on/of switch for rest
Posted on Jul 26, 2010
I have a john Deere stx38 yellow deck Kohler motor does this mower have any fuses that has anything to do with getting fire
Hello I'm wade No it doesn't! It is all ran by key switch. If you can remove air filter and spay starting fluid in engine if it starts then you having fuel delivery problem. Fuel shut-off solenoid usually sticks not causing fuel to get into engine and that solenoid is what kills the engine when key gets turned off. If you have any further question I'm here to help. Wadembly@aol.com
May 07, 2015 | John Deere Garden
I have a john deere stx38 it will not fire put new coil and spark plug still no spark cranks good and magnets are clean what could it be
did you set the gap between the magnets correctly. if not you may not be getting the voltage you need to create spark.
Jul 20, 2013 | Garden
I have an older john deere stx38. engine starts and runs fine, engage the blades and and engine does not bog down. with the clutch engaged, the shifter moves through the gears smoothly. left the clutch...
I had a similar problem and it turned out to be the automatic belt tension was blocked with grass so it was not tensioning the belt correctly. It was quite difficult to completely clean it but it has been fine ever since.
Jul 08, 2017 | John Deere 420,1020,2010,2020,2510,2520...
I have a john deere stx38 and it has no spark and wont fire but engine turns over
Check the shear pin in the flywheel, replace if bad, should cure your no spark problem
May 28, 2011 | John Deere Pto Clutch For Stx38 And Stx46...
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
Stx38 won't start
Actually, this is a problem with many lawn tractors. John Deere makes a "Starter Assist Kit" that sells for about $25. After time, the electrical connections get a bit corroded and when you turn the key the solenoid doesn't get the full current it needs to be activated. I have made my own relay to overcome this problem on my STX38, have shared with many folks with positive results as well. Cost is about $5 total. If you still have this problem and would like a schematic of the "fix", go to:
Mytractorforum.com, go the the Lawn and Garden section, click on John Deere. When the page opens, search STX38 and look for the thread started by "Brad". Info is in there.
Good Luck.
Apr 06, 2009 | Garden
John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers Logo
974 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
