Question about Danby DPAC90061 Portable Air Conditioner
Danby dpac 90061 various problems
I have had this unit for 3 years this summer. It is not cooling nearly as much as it was last summer, Also it will shut off and blow just regular air that it pulls in from the intake. I have cleaned out all the filters on the unit and still nothing seems to be working 100%. It also is no longer filling the reservoir tang, I actually have to put the attached hose which is to go outside the window (does not drain properly that way) into a big bucket in my room otherwise there seems to be dripping from the bottom of the unit.
I have misplaced my manual to see the troubleshooting section (if there is one in the back) to see if there is anything else I could possibly try to get this unit to work.
  • Danby Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
I installed a fujitsu asu24c1 unit in my garage a few years ago. I used it for one summer, didn't turn it on last summer and when I turned it on this year it wouldn't cool. I have troubleshooted...
With the limited information i would suggest the following:
Check to see if the outdoor unit is running.
If the outdoor unit is running, grab the large copper line coming out of it and see if it is cool.
If the fan outside is running and the line is not cool then the compressor is not running or the system has lost its refrigerant charge.
Check these things and repost for a more complete answer.
Hope this helps.
Sep 05, 2011 | Heating & Cooling
Danby dpac 10071 air conditioner is not cooling. a red light is on next to an icon with a full cup. Does anyone know how to make it cool?
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Danby DPAC10061 Air Conditioner
Danby Portable A/C Model DPAC 11007, purchased Costco May 19, 2007. Platinum Warranty. For the first few years A/C( only) operating it was not necessary (or rarely) to empty the external tank Then last ...
Eugene, first, let me say, yours is one of the best narratives, of what is happening with your ,that I have read in a long time. You didn't leave me guessing as to what was going on.
I believe one of the problems is that you may be operating the AC Cooling & the Dehumidifier at the same time. If this is the case, the dehumidifier is generating heat, when it's operating and the AC cooling side is working at a lower rate, because the dehumidifier is in operation. Discontinue the use of the dehumidifier on extremely hot days and use only the AC Cooling mode. The AC mode also acts somewhat as a dehumidifier. That's why draining the water tank is required for AC mode too.
I would also be prudent to check the exhaust hoses to make sure they are not clogged or have been bent out of shape. Keeping the air intake filter clean is really important, too.
Aside from the air conditioner, other things can be done to help cool the room. Close all drapes or blinds to block the sun from directly heating the room. This is especially true, if the AC unit is sitting in direct sunlight. If you have a ceiling fan, operate it it as fast as you can stand, in a Clockwise direction. This not only keeps air moving, it also helps the AC unit and creates a windchill, that fools your body into thinking it's cooler than it really is. Personally, I have been doing this for years and have saved a ton of money on electric bills during the summer.
I hope I have been able to help you and thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
Very hot exhaust hose on my danby 90061
check the air filters for blocked airflow some heat is normal this is how the unit gets rid of the heat it removes from the room
Jul 21, 2011 | Danby Heating & Cooling
I bought my Haier HWR 10xc6 mid summer of last year. Used it for two weeks and it was fine. Didn't use it much as went out of town the rest of that summer. I turned the unit on last week and set the...
Hello, it can be a few things. 1) plugged air filter and evaporator coil 2) low refrigerant charge 3) the compressor is not engaging If you are willing to check out a few things i can tell you exactley whats going on with your ac
Jun 07, 2011 | Haier hwr10xc6 Air Conditioner
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
Danby DPAC90061 Portable Air Conditioner Logo
377 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
