How do i remove the fan motor bracket from old motor and put on new motor
    President:
  • 1,515 Answers
Hi, if its the type of bracket that has 3 legs on it as on a blower motor, you have to loosen the bolt and nut far enough to get the bracket to slide off of the motor. They can be a pain at times, but that's the only way You can remove the bolt completely and spread it. If you are talking about some other kind of bracket, please let me know. You have to spread it enough to clear the wires coming out of the motor.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Posted on Jul 09, 2010
Where is the capacitor
This is NOT the capacitor! I would not go opening up the control panel unless you know what you are doing as the voltage in there will put you to sleep permenantly. It sounds like the fan motor is about to go out. The unit will have a safety cutout switch by the unit. Metal box with either pullout or throw switch. Disconect unit using this, open top cover by unscrewing the holddown screws. Motor will have serial #, voltage, hp rating, rotation direction all of which you need to order a new one. remove wires, labeling them as you do so. Loosen mounting bracket around motor. Fan can be removed by loosening the set screw on the motor shaft. Measure how far from motor the fan is and make note as it needs to be put back in the same position. Set fan to side and remove motor from housing bracket. Put new on back in reverse. My BEST advice? Hire a pro for this!
Apr 22, 2013 | Goodman CKL36AR36 Air Conditioner
How to replace the condensor fan on GE Mod.gdl20kcsabs --bottom freezer
How To Replace the Condenser Fan The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it.
If the fan blade is damaged, it can be removed from the fan motor and replaced separately.
Caution:Please read our safety information before attempting any testing or repairs.
cautiontri.gif Before replacing the condenser fan, unplug the refrigerator to avoid an electrical shock hazard.
The fan motor is held in place with screws and possibly a mounting bracket. Remove the bracket and the screws and pull the motor back away from the housing.
The fan motor is connected by two or three wires. Label the wire placement on the motor before disconnecting the wires. The wires are connected to the terminals with slip-on connectors or a plug. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Remove the fan blade from the old motor and install it onto the new motor. Connect the wires to the new motor and install the motor into the bracket or housing. Make certain that all of the screws are tightened securely.
Replace the access cover (if any) and plug in the refrigerator.
Jul 15, 2011 | Refrigerators
Removing the GE refrigerator condenser fan motor. What screws and other items I need to remove to take the fan out and replace it.
Unplug unit. first you have to disconnect the wires. sometimes there is a connector plug if not cut the wires. then you can take out the three screws that go into motor or remove the brackets with motor, take motor out of brackets, install new motor in brackets and reinstall. there is usually one screw that is hard to replace. you don't have to worry about which wire is which since it is AC. takes me about 30 -40 minutes to do
Jun 22, 2011 | Refrigerators
Move existing ceiling fan to another location
make sure light switch is off.
start by unscrewing the fan blades. take out bulbs and bulb covers etc.
once all thats down the fan and light switch cover has three screws you can take out and unplug it to get it out of the way. look around the base for some more screws to take out and remove the big cover thats covering the motor. get it out of the way. now you will see the bracket thats holding the motor in place. remove them screws and bolts, but be careful and ready, the motor is heavy, and as it comes down, normally hamptom bay has a coat hanger type hook that will let you hook the hanging motor on the hook long enuff to disconnect the wires ONE AT AT TIME and then put the wire nut back on it just for safety. when they are all disconnected , you can un hang the motor , and then inspect the new fan bracket, it probably fits the same hanger. but if not, you need to take the bracket motor hangar down and get the wires out of it. if the light switch is off IT WONT SHOCK YOU. just dont touch the bare wires to your hands ANYWAY. if they touch each other thats ok. IF THE WALL SWITCH IS OFF. ok now its removed.
Jul 31, 2010 | Hampton Bay 24002 Ceiling Fan
How do I remove and install new Water Pump for 1 1999 Kia Sportage?
Kia Sportage 1998-02
Water Pump - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    Negative battery cable Lower splash shield Upper and lower radiator hoses Coolant reservoir tank hose Fresh air duct Fan and shroud Loosen the alternator mounting and adjusting bolts Alternator belt Fan pulley and bracket Upper and lower timing belt covers and turn the crankshaft until No. 1 cylinder is at Top Dead Center (TDC). Loosen the tensioner lockbolt and pry the tensioner away from the belt Timing belt Loosen the tensioner bolt Water pump Tensioners from the water pump
To install:
Fig. Exploded view of the water pump mounting
  1. Clean the surface of any old gasket material.
  2. Install or connect the following:
    Tensioners on the water pump Water pump and gasket. Torque the bolts to 19 ft. lbs. 25 Nm). Timing belt Loosen the tensioner lockbolt and allow the tensioner to rest against the belt. Torque the tensioner lockbolt to 32 ft. lbs. (43 Nm). Upper and lower timing belt covers Fan bracket assembly and fan pulley Drive belt Cooling fan and shroud Position the radiator and torque the bracket bolts to 89 inch lbs. (10 Nm). Torque the shroud bolts to 89 inch lbs. (10 Nm) and torque the alternator adjusting and mounting bolts Position the fresh air duct over the radiator and tighten the retaining bolt 89 inch lbs. (10 Nm) Radiator hoses and tighten the clamps Lower splash shield Negative battery cable
  3. Fill the cooling system.
  4. Start the vehicle and bring the engine to operating temperature. Check for leaks and repair if necessary.
Good luck (remember rated this).
Jun 22, 2010 | 1999 Kia Sportage
How to put new belt on
remove back, loosen motor bracket, remove belt, put new onw on, belt size on belt, move motor on braket to put tention on belt tighten motor bracket
May 08, 2010 | Whirlpool Dryers
My bathroom fan was barely running when now it doesn't run at all,
Hi, W/D here.
These fan motors are fairly rugged, but they do give out sometimes. I have to change them out occasionally, and here's what I do: If the unit is presentable, I don't want to change out the entire unit, just the damaged part. The fans come in a variety of sizes (the ceiling box part, that is) and it is difficult to find one that fits in the same cutout. I unplug the fan from the receptacle in the ceiling box and remove the motor and mounting bracket. I buy the economy version of the fan, or the motor replacement kit at Lowe's/similar, and mount the new motor and fan blade in the old bracket and reinstall. Total cost is ~ $20.
Best regards, --W/D--
Aug 13, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Replacement of fan oven element on Nef U1721
Hi Steve...yes, these are a pain! Remove the centre fan nut (which is anti-threaded) then lever off the small locating washer underneath. If you are lucky, you will be able to now pull the fan blade off of the motor shaft. However, very often they won't budge!. If you try to knock it off, it is so easy to damage the fan motor (about £80!!). It is possible to leave the top bracket screwed to the oven and unclamp the element from it. I have come across three different typed of clamps so far. One is very easy to do. You can then remove the clamp from the new element and once the element is in place, use the old clamp. It's a fiddle but quite do-able. I have also come across these where the top clamp has been previously removed altogether by engineers on previous repairs! Hope this all helps a little....
Jun 24, 2009 | Neff U1721 Double circotherm Electric Oven
Molding inside door on freezer is very warm to the touch. Almost hot. Model TFX27EKC (21 YRS OLD) Freezer side seems to be working, but systme check on door, gives code FF. Refrigerator seems to be...
Hi WR,
Your symptoms scream "failed condenser fan motor!". This old unit is definitely worth the repair (one of the last of the great GE's). Here's the thing, the fan motor for your fridge calls for a #WR60X187 and this one runs about $110.00! There IS another option... part #WX4X988 (and this one costs about $40.00). They are BOTH manufactured by GE and they BOTH have the same RPM. The only difference between the 2 motors is how they hook up electrically.
IF YOU CHOOSE TO REPAIR... UNPLUG YOUR FRIDGE FIRST!
Take a look at this link. This is the motor that is a direct replacement. You'll see 2 thumbnail images... look at the second one. See that black thing at the top? That's the electric connection.
Now look at this link. This is the SAME motor, but with different wiring. All you have to do to install this one is to cut the plastic connector from your original wire harness, strip the wires and wire nut it to the new motor.
By the way, I failed to mention where the motor is located. Clean off all the stuff from on top of the fridge, then roll it out into the kitchen. Now get behind it and remove that cardboard cover there at the bottom. I think your condenser fan motor is on the left side. (hint---> it's the thing with the 6" fan blade mounted to it). When you get to this point, you'll see that the fan is either not spinning or is spinning slowly... either way, ya gotta replace it.
There are only 3 screws mounting the motor to the bracket. Remove those and pull the motor. Remove the fan blade from the old motor and put it on the new one. Then just mount the new motor to the bracket and button everything back up!
(TIP! ---> While you're doing this repair, you should take this opportunity to vacuum all the dust outta the compartment back there.)
If you have any questions just write back.
SG
Jun 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag mfd2561he bottom freezer
I had the same problem. I removed the rear panel of the freezer (4 screws), removed ice maker, and found the evaporator fan that blows cold air from the freezer to the refrigerator was bad. I removed old fan and began calling around for the replacement part. Turns out the original encased fan motor went bad because the motor was encased and condensation caused the motor to go bad. The new motor came with brackets and new unenclosed motor. Took 1 screw driver and about 1-2 hours of work. Make sure power and water is off before working on unit.
May 14, 2007 | Maytag MFD2561HE Bottom Freezer French...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
