Question about Craftsman Garden
Somebody gave me a Craftsman lawnmower with a B&S 7 HP motor, YBSXS.1901VE 275078, because he couldn't get it started. I put gas in and it ran out of the primer bulb so I replaced the primer bulb. Now it's better but still leaking gas. I wouldn't assume there would be gas present in the bulb or at least some kind of check valve in place. I can't find a parts breakdown for this model to see what is in the carb. Can you give me some advice please?
  • 755 Answers
Under the carb is a metal bowl. This bowl houses the carbs float attached to a needle valve. This valve is probably stuck open due to corrosion or dirt blocking the opening. You can remove the bowl with a half inch wrench and lower the bowl from the carb. Let some gas flow out of the needle valve and work the float up and down to help clear out the obstruction.
Push up on the float and see if the fuel flow stops. If it does you can put the bowl back on and see if it stops flowing out the primer bulb.
If it is still flooding you probably need to replace the float, and needle and needle seat. These are pretty inexpensive you can order them online *(ebay might even have them!).
You might want to clean the main jet too. You should get this carbs diagram to show you where the main is located.
Posted on Jul 09, 2010
Testimonial: "Leaking stopped but mower still would not start. Soaked carb in Gunk & the bowl gasket stretched, have ordered an overhaul kit. Research showed the mower model as 917.377240 w/ motor 128602 0304 E1 w/ Walbro 214661 carb. Kit # 692703 or 792383 Thx"
  • john andrew manchook Jul 19, 2010
    get a float too! I see the rebuild kits dont have floats in them.
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
My craftsman gasoline lawnmower will start when primed run less than a minute then cut out . how do I determine the problem...then fix it
Have you checked the fuel supply first. Its possible your jet valve may be plugged or dirt in the fuel bowl. One quick way of checking this is take the spark plug out and put a little shot of gas in the spark plug hole then reinstall the spark plug and put wire back in place and try to start engine. If it start and revs up for a few seconds till the gas is burnt up then stalls it is pretty certain its a dirty fuel jet or dirt in the fuel bowl. This quite often a real cheap fix .
Jul 20, 2015 | Craftsman Garden
Ybsxs 1901ve
part number 690610
May 25, 2013 | Garden
I need to find free diagram for linkage hookup on a 10 HP Briggs & Stratton Snapper riding lawnmower
I would go to mytractorforum.com, click on the word 'forum' just to the right of the tractor wheel, and scroll down to the small engines and repair section. Inside 'stickies' is a directory of B&S service manuals.
Apr 14, 2013 | Snapper Garden
How do I connect wiring on Kohler CV16S motor to craftsman mower that had a B&S YBSXS.7242VFmotor?
You need to know which ones are the kill wire, charge wire and starting wire for both side of the harness and make you own connector.
Dec 06, 2017 | Garden
B&S 7 HP motor, YBSXS.1901VE Starts very hard - then runs great.
Needs more fuel on start-up adjust fuel or choke more. RayC
Sep 03, 2011 | Garden
Centura 3.8 HP Tecumseh lawnmower not working w/o starting fluid
main jet blocked needs carby service its worth it
May 12, 2010 | THQ The Lawnmower Man
Crafsman Eager 1 6.75 HP lawnmower wont start
I have an Eager 1, as well and when I try to pull the cord it does not turn at all. It's stuck. I hit a tree root and since then I have had problems with it. I have 2 mowers so it was not used last year at all. Gas was drained and it was stored in a shed. Anyway, I know nothng about mowers other than spark plugs, gas, oil, sharp blades and filters. Is the motor seized? Thanks
Feb 15, 2009 | Garden
Garden Logo
1,225 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
