posted by Nadeem Nawaz on Apr 19, 2008
istall the ram but do not desplay
ram is out of socket and than buzzer 3 bip
please solve the problem
ok sir thangs
Comment by Nadeem Nawaz, posted on Apr 21, 2008
hello sir
ram is no detected
all of ram is install
but do not desplay
and 3 buzzer
ram is no detected
but do not desplay
and 3 buzzer
nadeem.it@kamal.com.pk
2 Other Users Have The Same Problem
Comment by Guest, posted on May 22, 2008
istall the ram but do not desplay ram is out of socket and than buzzer 3 bip
I was install Ram to other mother board Ram is ok
and same problem in 3 mother board Intel 845 glly
Comment by Guest, posted on May 19, 2008
my pc turn on but fan is on mother led display but vga not display and also processing led display continues bi linking
Solution #1
posted on Apr 24, 2008
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Luck!
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Intel D845GLLY Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
Beep Sound on Upgrading RAM On ...
i checked may web sites and... Answer This...
Repair Service
Find Motherboard Repairman Near You:
