Question about Sony Handycam CCD-TRV87 Camcorder
Wont close for tape
I have an old sony handycam trv-87 and the tape ejector wont close when i put a tape in. it powers up just fine, wondering if there is a simple solution to fix this before i take it in somewhere. Thanks
  • punky76 Jul 09, 2010
    any recommendations on a way to get them to CD?
    Problem Solver:
Sounds like a possible tension spring on the latch has broke, or fallen off, the latch is on the side of the tape compartment, looks like a small hook and is locks around a pin if the spring is broke or the pin has gotten bent, that is your problem.
Posted on Aug 17, 2010
    Sergeant:
  • 275 Answers
I have a model similar to this one. Best bet is to copy tapes to CD and buy a newer one which is what I am going to do soon.
Also Vista doesn't even work with these, just xp.
Posted on Jul 09, 2010
  • Steven Monser Jul 14, 2010
    What I started to do was to download them to my pc that has xp , put it in a folder and copy it to a cd or dvd.
    An easier way, which is what I am doing now when I get spare time is to plug the camera directly into my DVD recorder with the cables provided and just hit record and leave it to do the whole tape.
    Sooner or later these tapes will self destruct just like VCR tapes.
  • Steven Monser Jul 20, 2010
    Did this help you at all? I forgot you can't get the tapes in or out. Very hard to keep up with technology, sometimes hanging onto old equip too long like I sometimes do, doesn't work. Planned to be obsolete before you even take them home.
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: "reinsert the cassettee" error in Sony HandyCam CCD-TRV 438E.
The camcorder most likely is not detecting the tape, you have a bad sensor and these sensors all come on a flex type board and the flex board is mounted on the chassis surface. This will mean that the entire mechanism will meed to be diassembled, and is a very big and costly job. My opinion is that this repair will run you abut 250 to 300 bucks and this camcorder is not worth this as new camcorders are under 200 bucks. Good Luck
Posted on Apr 03, 2007
SOURCE: tape door wont close
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Posted on May 13, 2007
  • 149 Answers
SOURCE: ERROR C:32:11
GO TO REPAIRING INTERNAL PROBLEM
Posted on Sep 10, 2009
CCD TRV 87 Camera eats tapes. Any thoughts or suggestions?
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
Aug 14, 2010 | Sony Handycam CCD-TRV87 Camcorder
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
ERROR C:32:11
Sep 09, 2009 | Sony Handycam DCR-TRV140E Digital...
Tape ejector won't stay closed on CCDTR67 NTSC Sony Handycam
This equipment is almost twenty years old - time to replace it.
May 03, 2017 | Sony Handycam CCD-TR67 Camcorder
Flashing error message C:31:23
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jan 09, 2009 | Sony Handycam DCR-TRV240E Digital...
Viewing SONY 8mm Tapes -- Please help
The older tapes were shot on a 8mm camcorder and the camcorder you have wil not play them becasue it doesn't have backwards compatability with the older format. The tapes you recorded are on a digital 8 camcorderr and it is different encoding than the one you recorded the other 60 tapes with. You will need to find either a dcr-trv 350 trv 530 trv 730 ect as these have the ability to play all the tapes.
Or find an older 8mm camcorder to play your tapes with.
Hope this helps
Cheers
Al
Nov 01, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony Handycam DCR-TRV330 Digital-8 won't calibrate tapes to be able to view
hi there. i just actually had this problem right now. and heres how i fixed it :) it had the error so i took out the tape left it ejected for about 5 seconds. then put the tape back. it read for a little then errored again so it was close. next what i did is plugged the camera in (last time this error happened i plugged in the power and it fixed it) still no fix so i took off the battery waited 5 seconds then put it back on. after that i ejected the tape again and re put it in and it worked! you could try anyone of those things. and usually they work for me. maybe it has something to do with the cameras being old.
Sep 16, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Tape door wont close
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Open Questions:
See all Sony Handycam CCD-TRV87 Camcorder Questions
Sony Handycam CCD-TRV87 Camcorder Logo
266 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
