ATI RADEON? X600 Pro,  PCI Express Graphic Card
Problem for ATI RADEON? X600 Pro, (128 MB) PCI Express Graphic Card
Driver
By elli8 on Apr 19, 2008
ati2dtvg gets stuck in loop
Same Problem
Jun 20, 2008
-   Yep, same problem I suspect. Running WinXP/SP2 on HP Pavilion ZD8001AP with Radeon Mobility X600 .. .. screen goes white after displaying the Windows XP logo. Workaround (use native VGA resolution, but looks rubbish) is to use F10, boot safe-mode, disable video driver & reboot. Worked properly for many years, but suddenly went bad like this in last few months.
Any ideas gratefully rec'd.
-   GreenWash
May 19, 2008
-   I have the same problem, please help!!!
-   Elvir
Best Solution
posted on Jan 04, 2009
Very Helpful)
MORRISS
Rank: Wiz
Rating: 88%, 25 votes
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers (you will need to do this at native vga mode).
You should have downloaded the most recent catalyst drivers from ati or the manufacturer of your pc.
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are DONE!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for ATI RADEON? X600 Pro, PCI
Questions and Unsolved Problems for ATI RADEON? X600 Pro, PCI
Do you recommend ATI RADEON? X600 Pro, (128 MB) PCI Express Graphic Card?
Answer
Answer
i've purchased brand new ''gforce fx 5500 inno3D 256mb (128 bit) w/ CRT DVI+TV out'' to replaced my... (More)
Answer
so i just got sims 3 for christmas as well as my brand new ace aspire. and they dont work... (More)
Answer
MSI mobo with P4 2.8 and INTEL 865PE/G chipset will not recognize my new XFX ATI Radeon 4650 AGP... (More)
Answer
need hardware craphic acceleration when i wanna run fifa world cup 2006
Answer
After upgrading to Leopard, installing a 500 giga external drive for effortless time machine... (More)
Describe your Graphics Cards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Graphics Card Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
