Question about Hitachi EC89 4 Gallon Twin Stack Air Compressor
Keeps blowing the breaker... only 6 months old
Hitachi ec89 compressor keeps blowing the breaker... only 6 months old, seems to be common problem with this compressor
    President:
  • Hitachi Master
  • 1,383 Answers
This compressor is small however like other brands in this size range draw 13 - 15 amps. Thats quite a bit of power. The compressor has a thermal breaker that will begin to trip if compressor is hot. I am assuming that the breaker that is tripping is the one on the compessor. I have seen many hitachi breakers fail. Easy to replace with generic 20 amp, cost about $10. Before you replace anything, check amp draw with meter, if within specs try to determine what is causing heat.
example:
cycling too many times per hour (check manual for recommended)
low power due to weak circuit or extension cord
using generator for powering compressor (not recommended)
using low quality oil (use synthetic if hot climate)
air leaking from intank checkvalve back to pump
If no reason to overheat then replace breaker on compressor to 20 amp but watch for overheating. Good luck
Posted on Jul 10, 2010
  • Freddie Johnson Apr 22, 2011
    The early Hitachi EC89's came with a 40 microfarad capacitor to start the motor. This is insufficient when its cold, or the compressor hasn't been used in a while, or the compressor is still in its break-in period. Hitachi later changed it to a 60 microfarad capacitor, as it now is with the currently offered EC89's, which provides reliable and consistent starts of the electric motor. FYI: the capacitor is the white tube looking thing just under the black cover on the top side of the compressor. You can just see it without disassembling anything if you peek under the black cover to the best of your ability. To get at it you need to remove the black plastic cover. To do that, it takes about 20 minutes of disassembly time and a few tools: unplug the compressor, disconnect at least one end of the copper pressure tube (the tube that runs from the pump to the tank), remove the four main bolts that hold the black steel compressor base to the main frame, now you can get at the four phillips head screws that hold the plastic cover on, loosen (but don't remove) these four phillips head screws, then pop off the plastic cover (there are anti-vibration side locks that need to be disengaged- by using a long flat head screwdriver from the inside- to pry them and pop them off from the inside). Once the black cover is loose, you will either have to reach in and disconnect the two wires to the breaker, or unthread the breaker's little hex nut and separate it from the black cover. Replacing the 40 microfarad capacitor with a 60 microfarad capacitor (available at your local electric motor rebuilder- yellow pages) will resolve the problem of the weak starting motor that pops the breaker before the motor gets a chance to start rotating. Shame on Hitachi for not publishing this fix themselves.
  • John Trevino Apr 23, 2011
    Good job, welcome to the the community (not my job to welcome anybody however noticed that you are new ) , I hope to see your repair suggestions in the future so that I can learn more tricks of the trade. I was involved in the tool rental industry while attending college and worked with the service people as well as factory reps. I like your long and clear message. This will help when trying to answer others. I have answered /try to help hundereds of folks, however you will find that people tend to ask unclear questions making it very difficult to solve. Lately I have chosen not to answer a question if it is not clear and does not have model numbers, but I make exceptions if I know what item they are trying to repair. It is mostly a thankless task because very few people respond. I find that I am answering the interesing / uncommon problems if I know the solution or can ask friends in the industry / inquire / investigate the issue with a factory rep. etc. I will watch your progress and feel free to email if you have a question yourself (although I think that you have vast knowledge) there is always an opportunity to learn something. I have tried different capacitors on equipment, however the old timers, (service guys ) allways suggest measuring the amp draw, the instant high, and normal / run and stick with the capacitor that actually has the lowest initial draw/ run. Your trick is worth mentioning, after all the air conditioning industry does it all the time (hard start cap.) Thanks for taking the time /interest to help others!
Hitachi EC89 air compressor just hums and reset button pops..doesn't turn on at all..
it indicates that the start / run capacitors are failed
remove the power lead from the wall and get the details from the capacitor/s and go to a motor rewind shop and they will have replacement capacitors available
if you can take the capacitor/s with you it is even easier
Oct 26, 2015 | Hitachi Air Tools & Compressors
I found a ec89 , 9/10 at a pawnshop for $50 , BUT it dosent build pressure. How much would ya guess to repair it and good buy or stay clear? Thanks
I dont know what it cost new, but I dont think it cost as much as you are thinking. Here is a parts list an exploded diagram to replace parts. If the part is cheap enough then here is the link to it.
Hitachi EC89 4 Gallon Portable Twin Stack Air Compressor Parts
Jan 28, 2015 | Hitachi EC89 4 Gallon Twin Stack Air...
Htachi ec89 Thermal Protection trips
Its your reset button on the compressor that's bad! I have the exact same compressor (EC89) and it did the same thing! Compressor would run great for 15-20 seconds, then trip the reset button. I ordered a new reset button off e-bay, replaced it, and it works fine now. Good overall compressor! but has cheep china electronics installed. just replace the reset button and you will be good to go....cheep fix!!!
Sep 01, 2012 | Hitachi EC89 4 Gallon Twin Stack Air...
Hitachi ec89 will not shut off
IF it is building up to the correct pressure then the pressure switch has malfunctioned. The part number for a new switch is 160580.
Parts and owners manuals are located at this link near the bottom of the page;
Hitachi EC89
Aug 19, 2012 | Hitachi EC89 4 Gallon Twin Stack Air...
Very hard to start when cold, even in temps above freezing but below 60 degrees.
Feb 27, 2011 | Hitachi EC89 4 Gallon Twin Stack Air...
The overload keeps tripping
I have had a Hitachi EC89 compressor for a couple years now. As an Mechanical Engineer with a minor in Electrical, I observe that the motor assembly/capacitor is undersized for the mechanical energy it is asked to produce upon start up. The motor consistently struggles to get up to speed, requiring too much electrical current and then the breaker pops, and you're back to time zero. And the cycle repeats. In other words, the fundamental EC89 design stinks and it should not have been released onto the market in this way. I replaced the capacitor on mine with a more robust G.E. version and it has improved, but fundamentally, there are not enough motor windings to get the system going good & strong, each and every time. Shame on you, Hitachi.
Feb 08, 2011 | Hitachi EC89 4 Gallon Twin Stack Air...
Hitachi EC89 4 Gallon Twin Stack Air Compressor Logo
813 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
