Question about Powermatic 1352001 3520B 20x35" Wood Turning Lathe
The digital speed readout stays on 0
This machine has just been installed, never used
1994 Cadillac Eldorado speedometer stays on zero
Unless you have a totally stripped-down Eldorado, your speedometer is most likely ELECTRONIC (probably even has a digital readout).
Check your Trip Computer. Has it stopped reading fuel economy, distance to empty, etc.?
Is your odometer also not adding miles as you drive?
If affirmative to all of the above, replace your SPEED SENSOR, and you'll be all set :)
Jul 22, 2014 | 1994 Cadillac Eldorado
Treadclimber centering
Dear Sir:
ecalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the TreadClimber by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 15, 2012 | Exercise & Fitness
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
Hello i m looking for a washing machine for our family we have never used washing machine. we have 7 members in our family which is the right machine for us?
Stay away from a Calyspo, Neptune, Elite. These are problem machines. I would also stay away from any of them that have a digital readout. Water and that type of electronics do not mix. I have a whirlpool top loader that has a dial. It's over 13 years old. I have replaced a pump twice and repaired the lid switch. Simple fix and the cost was small. Most people have trouble with washers due to overloading them. I never overload mine inso it has given me good service.They still make these machines under different names like maytag, roper and kenmore which are owned by whirlpool. Front loaders leak and give problems in a couple of years.
Jan 16, 2011 | Washing Machines
Fill level & digital readout (bemis humidifier)
There is a sticker that comes in the owner's manual that apparently falls out frequently. I was told that the fill level is two inches below the top edge of the reservoir. I am going to mark mine with a Sharpie since stickers have a tendency to fall of when wet.
Jan 05, 2009 | Bemis Whole House Digital Humidifier ED11...
Having problem programming personal speed dial on norstar 7208
Sounds to me your trying to access your speed dial bins feature 0 then your speed dial will get you to the speed dial bins 71-92 this is your personel spedd dials your phone only 0-70 are system wide speed dials . Feature * 4 is not a feature in norstar systems.
Sep 26, 2008 | NorStar T7208 Corded Phone
Screen Readout
yes screen readout is bad... u need a new screen
May 01, 2008 | SanDisk Sansa E280 MP3 Player
Powermatic 1352001 3520B 20x35" Wood Turning Lathe Logo
27 people viewed this question
Top Powermatic Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Powermatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
