Question about Cameras
Finepix F30 screen cracked, can it be replaced, if so is it economical to do it
  • Anonymous Jul 04, 2008
    Screen cracked on a Fuji pinepix F480 Digital camera. Is it possible to get a replacement screen? If so, howdo we go about this?
  • 13,433 Answers
Posted on Apr 19, 2008
Lcd broken.Any chance to change lcd.
yes LCD's are a pain to replace on your own but luckily I'm here to help... please remember to rate me for helping you
the easiest way is to buy a new LCD
such as here:
finepix-f30-digital-camera-repairing-lcd-display-screen-replacement.html">http://www.ownta.com/fujifilm-finepix-f30-digital-camera-repairing-lcd-display-screen-replacement.html
or on ebay:
http://cgi.ebay.com/FUJIFILM-F40-REPLACEMENT-LCD-DISPLAY-REPAIR-PART_W0QQitemZ320283316623QQihZ011QQcategoryZ64352QQcmdZViewItem
Follow link to ebay vendor: Most lcd display screens are available
or you could build your own but without a ton of experience, this is more of a challenge than it's worth.
I hope this helps :)
Jan 04, 2011 | Fuji Cameras
How do i replace LCD screen
Hello
The video below should be sufficient.
Kind regards
Andrea
Sep 29, 2010 | Fuji FinePix F30 Digital Camera
Need the time and date to print out on my photos the camera is finepix f30 i have no instructions
Menu screen set the language,date and time then go to your photos on the playback screen =(green arrow) then press F button scroll down to print order (DPOF) select print with date.
Mar 24, 2010 | Fuji FinePix F30 Digital Camera
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
Fuji FinePix F30 shutter problem: won't take pictures
Its fairly easily fixed and its a common problem with the F30. The shutter button contact slides off upon impact when dropped, it must be re-aligned so that it makes proper contact and performs normally. All that is needed is the special screw driver for the F30 (easily purchased online, just google it: "screw driver for fuji f30" ) or bring it to your local watch/jewelry repair store and tell them to open it up for you.
We have two F30's and they both have been dropped, both did the same thing with the shutter button. But both were easily fixed. Always keep the camera in a safe place and away from kids, they are very sensitive devices. Use the wrist cord when taking photos.
Nov 19, 2009 | Fuji FinePix F30 Digital Camera
My Fuji Finepix F30 has a broken shutter button. The problem seems mechanical, because it won't work in any mode. Can it be repaired?
Nov 03, 2009 | Fuji FinePix F30 Digital Camera
Fujifilm Finepix F30 compact digital, LCD is very dim.
its not a good idere to get them wet you know,
it could be repaired if you can strip it out and you may be lucky it could only need drying out to work again take care when striping it down dry it out in free air only dont apply ant heat to it
Oct 31, 2009 | Sharp Viewcam VL-AH130U Camcorder
Fuji finepix s5700-- LCD not working
your lcd is cracked internally. repair is not usually economical than to purchase new unit.
Jun 01, 2009 | Cameras
'Card not initialized'
I just bought a sweet FUJI FinePix S5700...
I could not for the life of me understand why I was getting this message, and I was getting very upset !!!
I have a brand new Sandisk 2GB card, and it was driving me CRAZY.
My solution turned out to be a very simple one.
When your computer sees your card and you need to format it, it will give you TWO options. Either format using "FAT32", or just "FAT".
The FAT32 option gave me no results.
I tried again using simply "FAT", and it works just fine!
GOOD LUCK!
Jun 28, 2008 | Fuji FinePix F30 Digital Camera
Downloading mini video from finepix f30
Perhaps you can take out the xd card and use an external card reader to transfer the photos.
Mar 05, 2008 | Fuji FinePix F30 Digital Camera
Cameras Logo
130 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
