Question about Xerox Phaser 8200 Laser Printer
8200 printer error
We have 15,004.45:61339.Can you describe this error message?
Thank you.
Hi
this is ? frm india... this is very easy problem....how can that i will tell when purchase this product the company will give useerr guide .....read & follow it.....................
bye.. bye..
Posted on Apr 19, 2008
Phaser 8200 won't start
First of all Printer's service
then see what is flashing in your printer's screen
Feb 14, 2014 | Xerox Phaser 8200 Laser Printer
Xerox 8200 printer error 15.004.45. How do I
If this is your first rodeo, contact www.inktechnologies.com. They can walk you through it and provide the parts.
Jun 28, 2009 | Xerox Phaser 8200 Laser Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Memory error
Have you try to restart your printer?
you may want to read below link. might be useful to solve your problem..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Mar 17, 2009 | Xerox Phaser 8200 Laser Printer
Error messge xerox Pahser 8200 09.007.42:11683
The yellow ink sticks are jammed.
Open the ink loader and ensure that the yellow ink sticks are able to slide in the ink loading chute. Remove any broken of partial ink sticks.
Dec 07, 2008 | Xerox Phaser 8200 Laser Printer
I have a xerox phaser 8200 colored printer. It has an error message it's 15.004.45:16589
Somehow your question was posted twice, I am just responding to remove this message from the queue
Dec 01, 2008 | Xerox Phaser 8200 Laser Printer
Error phaser 8200
This error message is related to the drum heater malfunctioning. It is basically 4 small halogen bulbs that warm up the image drum. Sometimes one or two of the bulbs will blow causing this error. The part # is 650-4228-00 Drum/Paper Heater assy. It is not extremely difficult to change, however you need torx bit screwdrivers to remove the components, also there is a very delicate paper sensor that needs to be removed, so you may want to have a technician replace it.
Hope this helps!
May 20, 2008 | Xerox 8200/DP Thermal Printer
Printer problem
Yep, that is an easy one.
The drum heaters are not working.
Easy way to tell is this. Turn the machine off, then turn the lights off so you can see the lamp glow better.
Look into the fan slots on the right side of the machine after you turn the machine back on. You should see an incandescent glow in the drum area. Give it a minute or two to come on, but I seriously believe you will see any lamps coming on.
Those are simple 120 volt 150 watt halogen lamps what warm the drum. One or both of them have blown fillaments.
They are a little time consuming to replace, and takes more patience than skill to do.
If you want a procedure for changing those let me know. You can buy them at Lowes or Home Deopt, anywhere that carries halogen lamps. The better ones cost less than $20 a pair, Xerox would want more than $200 for that assembly, when all is wrong is a couple of lamp filaments.
Apr 19, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
