Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have cub cadet 2130 tractor that blows the 20 amp fuse when turn the key to the start position when starting
blueextc3221
  • 15935 Answers
SOURCE: A short in the pto wiring perhaps?
Form what you are desribing you have a direct short, probaly in the wiring going to pto. I t has rubbed somewhere and is causing your short. Unplug the wires at connector close to your pto clutch and try it again and see if fuse stuill blows after you unhook it.
If the fuse still blows it is in the wiring going back up to thje switch. If the fuse does not blow after unhooking wiring connector the problem is in the clutch.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
  • 97 Answers
SOURCE: oil light blinking
Screw a test gage in the engine where the electric sending unit is. Check to see what the pressure is cold and after it is warmed up. It may be a bad sender.
Posted on Mar 17, 2009
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
  • 142 Answers
SOURCE: cub cadet repair manual
partstree.com may have then or call the manufacture
Posted on Sep 23, 2009
Cub cadet model LGTX1050 blows 20 amp when key is turned to start position.
You will have a short that is causing it to blow the fuse. Check and make sure the battery is correctly installed. Red + and Black -. Other than that you would need a ohm meter to track it down. It can be several things. Hope this will help ya
May 20, 2017 | Cub Cadet Garden
I have a 2006 Cub Cadet RZT 42 Zero Turn Mower that keeps blowing the fuse. It would blow the fuse after long periods of use but it's gotten shorter and shorter between fuse blowing. Now it blows the fuse...
you have a wire that is grounding out, I would check the wire coming from the connector on the voltage regulator to the battery. This is the one in the middle position, look for a rub through and tape it up.
Nov 02, 2010 | Cub Cadet Garden
Cub cadet 2160 when turning ignition switch in second position, starter motor starts spinning. blows 20A fuse
You have either a short in the solenoid trigger circuit, and a faulty solenoid. To check, disconnect the small trigger wire on the solenoid. Turn key to 'START'. If fuse blows, there is a fault in the wiring. If not, the solenoid is faulty.
Oct 31, 2009 | Garden
Cub Cadet zero turn:Engine starts and runs about 5 seconds before blowing 20 amp fuse.
You may have a faulty voltage regualtor that is blowing fuse. Have you tried a fuse that is 5 more amps?
Aug 24, 2009 | Mtd Gold 42" Zero-Turn Mower -
Blown fuses when mowing
you have a wire that is shorting out somewhere, i would trace the wires from the clutch all the way back to the fuse including the relay and pto switch. You will more than likely find your problem in the control circuit between the fuse, pto switch and relay since this is what is fuse protected.
Aug 06, 2009 | Oregon Scientific Electric PTO Clutch for...
I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
Jul 28, 2009 | Cub Cadet Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
132 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
