Question about Dell E153FP 15" LCD Monitor
I have a Dell cpu and a Dell flat screen monitor . The monitor was working fine last night. When I tried to check e-mail this morning the monitor would not boot up. Instead the on/off button is slowly flashing green. I have unplugged it from both the computer and from the electricity and it remains dark. The cpu seems to be working fine. I have had no problems with either before this morning and there has been no electrical outage or surge over night. Thanks!
SOURCE: dell monitor power button is flashing
If you have the monitor on, but no video signal (for whatever reason) you should get a floating "Dell Self Test Feature Check" window with red, green and blue lines on it that shows the monitor is actually able to display a picture. Disconnecting the video cable is the easiest way to try to see this, and would show if the monitor can display anything. If you don't see that with the power on and video cable unplugged, then the monitor itself is most likely the problem (since you said the power light is on). If this is the case, you would need to contact Dell Technical Support to see about getting the monitor replaced, assuming it is still covered by its warranty. If you are not sure about the warranty, tech support will be able to check that as well. While it is bad news, hopefully it will help. Larry Dell Customer Advocate
Posted on Sep 05, 2007
  • 558 Answers
SOURCE: dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
goo dluck if you want it fixed for you let me know
Posted on Mar 22, 2009
  • 167 Answers
SOURCE: LCD monitor no display - flashing power button
hello, my best guess is that the refresh rate is set for a crt monitor. hook your old one back up, if you can. and change it to 60 hertz or 70hertz. go 2 display properties then settings then advanced; then monitor. set the refresh rate as i said and turn off the computer, hook the new one back, and you should be good to go. good luck! and please rate this solution. if you need further assistance, reply
Posted on Apr 21, 2009
  • 180 Answers
SOURCE: My computer monitor will not stay on.
The problem may with the Ram inside your computer
Posted on Jul 07, 2009
  • 1684 Answers
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Corporate Computer
Posted on Jul 30, 2009
Monitor was working fine last night but I think Microsoft did an update last night and i can't get the monitor to display. I get a check signal cable box that floats across the screen.Also do not have the...
Please unplug the monitor cable from the back panle of the cpu and replug it back again ensuring a tight connection.
this should take care of the problem.
Jan 22, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Display problem with Dell Inspiron 537
If it displays nothing at all through the boot process it's either the cable or the VGA card. It may be that the computer has gone into hibernate as it was left on overnight. Try pressing and holding the powerr button.
Dec 06, 2009 | Dell Computers & Internet
Monitor is black but power light is blinking green. Worked fine last night, but this morning screen was black and light was bliking. Suggestions? Thanks!
Firstly check the power cables nd VGA port is it proper or not nd then if this is proper then ur problem might be in RAM remove the ram and rub it with eraser nd insert it again nd check CMOS battery also ....u will surely get a positive result....
Aug 31, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
I have an HPa6700y I purchased about three months ago.  At the time of purchase I installed a high-end graphics card myself (ASUS EAH4870 DK/1G Radeon HD) and it had been running beautifully until...
usually there are 2 problems: 1. a vga card overheat when running 3 games the vga card heats up. try using an case fan or adn a vga fan. 2. the game uses a high refresh rate in this case tri to set a default refresh rate from the vga driver. hope this helps
Jun 14, 2009 | Computers & Internet
Monitor falls asleep during/after startup
control panel
click power settings
set the monitor to never sleep or dim
same on all windows.
the monitor is totally programmable
why not tell OS?
windows 10?
or google
why does my windows 10 monitor go to sleep
10,000,000 hits
the defaults under windows, are always wrong,
it's to keep the FEDs happy with there Energy Star bs.
im on laptop now far far from USA
set it all to not use sleep etccetra.
Feb 28, 2017 | HP Computers & Internet
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Won't turn on
Seems that your CPU-Cabinet is not giving the video output for your monitor. Please check the powercord and other internal assembly (if possible) that runs in and around the cabinet and restart the machine.
Sep 08, 2008 | E-Machines eMachines Desktop PC
Can you connect external monitor?
check if it works fine with external monitor.,...
Sep 04, 2008 | Dell Latitude D600 Notebook
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Dell E153FP 15" LCD Monitor Logo
41 people viewed this question
Alun Cox
