Question about Cameras
Samsung l830 only has 1 shutter bit closing, and the other isnt there
  • bel123 Apr 20, 2008
    wow, thanks HEAPS, it worked ^_^
  • 13,433 Answers
It must be stuck in there, or has it droped out? try pressing the nearby areas of the cover it might pop out.
Posted on Apr 19, 2008
When i turn my nikon cookpix s6300 off the lens goes in but the shutter does not close all of the way
This require a bit of mechanical work.
Click on the link below and you will be able to fix the issue.
Click here -> Troubleshoot Camera Issue
May 17, 2012 | Nikon Cameras
My samsung BL103 camera takes good pics inside but ot outside. how do i fix
First make sure that you are in "Automatic" mode, and not in one of the camera's othe manual modes which may keep the shutter open for an extended period. But if you are indeed in auto mode, and it's still doing this, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 09, 2011 | Samsung BL103 Digital Camera
Just installed a new oven gas burner, do I need to adjust gas/air mixture? It is operating on propane
Most cases yes. It is very simple, close the air shutter to 90% close, you will see yellow flame, now open the air shutter until the yellow flame disappear, then open the air shutter a little bit more now you are done. Have fun.
Nov 06, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
When i turn on the camera the shutter closes, when I turn it off, the shutter opens
I dropped the camera and now the shutter opens when turning off & closes when I open the camera. But when it is open, the shutter will open a bit making it impossible to take pictures. What should I do or where do I take it for repairs?
Tks, Ruth
Sep 11, 2009 | Sanyo VPC-S500 Digital Camera
My Samsung won't turn on :(
Try to move the lens a bit or straighten it out, that usually works when it makes the three beep sounds.
Jul 22, 2009 | Samsung L100 Digital Camera
Look s like shutter is not closing
Yes, it requires removal and strip down to clean the shutter.
Test out the video. That should be ok as it does not use the shutter
Mar 19, 2009 | Samsung S1050 Digital Camera
sounds like the lil motor that is in charge of opening and closeing the shutter might have shorted out causing it to stick, or it could have just simply burnt out or striped the lil gears on the motor. If the shutter moves alil bit i would say you probably have a short in the shutter motor.
Dec 05, 2007 | Fuji Zoom Date 60 35mm Point and Shoot...
Lens wont shut completely
hello, as you said lens cover does not shut it means camera is in working mode so naturally it drains the batteries. Actually the problem is in the lens assy. so go to samsung shop. good luck...
Jul 27, 2006 | Samsung Digimax S500 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
