Question about Xerox Phaser 8200 Laser Printer
Printer problem we have 15,004.45:61339.Can you describe this error message? Thank you.
    President:
  • 2,072 Answers
Yep, that is an easy one.
The drum heaters are not working.
Easy way to tell is this. Turn the machine off, then turn the lights off so you can see the lamp glow better.
Look into the fan slots on the right side of the machine after you turn the machine back on. You should see an incandescent glow in the drum area. Give it a minute or two to come on, but I seriously believe you will see any lamps coming on.
Those are simple 120 volt 150 watt halogen lamps what warm the drum. One or both of them have blown fillaments.
They are a little time consuming to replace, and takes more patience than skill to do.
If you want a procedure for changing those let me know. You can buy them at Lowes or Home Deopt, anywhere that carries halogen lamps. The better ones cost less than $20 a pair, Xerox would want more than $200 for that assembly, when all is wrong is a couple of lamp filaments.
Posted on Apr 19, 2008
Error message
I'm sorry, I am not a mind reader. Could you please provide the following:
  • the number model of your printer,
  • the exact wording of the error message,
  • where you see it (computer or printer),
  • the program you are using when you get the message,
  • the operating system of the computer,
  • and the circumstances that cause the error message?
If you have physical symptoms that go with it (unusual noises, flawed printing, etc.) please describe those also.
Dec 14, 2011 | Office Equipment & Supplies
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Regards,
polysandy
Apr 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
Describe your HP Laserjet 2430tn problem: what
Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2410, www.hp.com/
support/lj2420, or
www.hp.com/support/lj2430.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
4. Try printing a job from a
different software program. If
the job prints, go back to the
first program and try printing a
different file. If the message
appears only with a certain
software program or print job,
contact the software vendor
for assistance.
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Mar 24, 2010 | HP LaserJet 2430tn Printer
WHAT DO i DO FOR ERROR # 1201?
The error message describes that: "The print carrier stopped before all of the data was used."
To reset the error code , try the following steps:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective.
  7. Contact Lexmark Customer Support for further troubleshooting and warranty options.
Jan 14, 2010 | Lexmark X4270 All-In-One InkJet Printer
Check printhead path error message
hi
the problem is nothing else but sofware..
you just reinstall the printer software.
Thank you
Sep 10, 2009 | HP DesignJet 1050c plus InkJet Printer
Label stuck inside HP Photosmart C3180
Follow the instructions given here, here & here for clearing a paper jam and cleaning the unit, and access the rollers from the back of the machine.(as described.) If you have problems clearing the error message, go to your home support page here, choose solve a problem, and see the error message solutions. As a last resort, reset the printer to clear a false error message.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | HP Photosmart C3180 All-In-One InkJet...
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
8200 printer error
hi
this is ? frm india... this is very easy problem....how can that i will tell when purchase this product the company will give useerr guide .....read & follow it.....................
bye.. bye..
Apr 19, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
46 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
