Question about AEG Lavamat 72640 Front Load Washer
Aeg oko lavamat 72600 update, ce error code showing any idea?
    Sniper:
  • 174 Answers
Error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Posted on Jul 20, 2010
Testimonial: "Cheers thanks very much, washer now working, great help"
  • 1 more comment
  • iljajo18 Nov 22, 2010
    Hi my AEG is doing the same thing.
    The clicking noise and CE error, is it easy to get parts and do it yourself or do you need a qualified person to replace it?
  • John Wilkinson Nov 23, 2010
    Parts are no problem. you have to remove the top and front facia . remove the srews of the metal frame to release the soap dispensor. the plastic clips that hold the dispensor halves together are a bit tricky once the halves are split you can pull it off the water valve. you need the 9 digit product or enr no to get the right part as there more than one version price approx £65. unplug the machine first.
  • Henrik Godiksen Nov 29, 2011
    Hi I just had the same problem with my AEG. I fixed the problem without any spare parts, maybe just temporary - lets see. I opened the top of the washing mashine and in the rear of the soap dispensor i removed a small black shield, two srews. Under this shield I found three colored plastic cogwheels. I pushed the cogwheels down because it looked like they was not realy placed as they should. Afterwards I assembled everything and it worked.
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Thanks
Jun 04, 2010 | Washing Machines
Oko lavamat 74640 update showing error E20 what does this mean?
its a draining error, check sump, pump and drain hose for blockage failing that it needs a new pump.
Mar 31, 2010 | AEG Lavamat 72640 Front Load Washer
My AEG OKO-Lavamat 72600 shows error code C9 what does this mean?
My ariston aqualtic has finnish as language how to change to for ex english
Oct 30, 2009 | AEG Washing Machines
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Jul 04, 2009 | AEG Washing Machines
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
AEG Lavamat 72640 Front Load Washer Logo
3,153 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
