Question about Fuji Cameras
My pictures are very blurry, what setting do i change?
  • kakima Jul 09, 2010
    That would depend on why the pictures are blurry. The possible settings would depend on the model of your camera. Not all cameras work the same way.
    The lens could be dirty. If so, clean the front of the lens (and the back, if you're using a camera with interchangeable lenses) with a lens cleaner.
    The subject could be moving. You can determine if this is the case by taking a picture of something that's not moving and comparing. The solution in this case is to use a faster shutter speed, or possibly using the flash if the subject is not too far away.
    The camera could be moving. You can determine if this is the case by putting the camera on a tripod, tabletop, or other stable surface, and comparing. The solution in this case is to use a faster shutter speed, and/or stabilize the camera.
    The picture could be out of focus. Try taking a picture of things at different distances. A long open road works great; get down low and get the painted stripe a few feet away all the way to mountains or trees in the far distance. Hopefully something between the foreground and the background will be sharp.
    If your camera has interchangeable lenses and you have another lens available, try that lens.
    There could be something wrong with the camera. If this is the case, you don't have much choice other than repair and replacement.
    Does this help?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Having received no response in over a month, I assume one or more of my suggestions helped.
Posted on Sep 02, 2010
Webcam snap photos
brettg12, Open up the WebCam Central Software and click settings. Once there choose to "Restore Defaults" to see if that will resolve the issue you are having with blurry pictures.Thank You,
Dell-Jesse L
Dell Social Media and Communitie
Jul 09, 2013 | Dell Computers & Internet
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
Pictures look blurry
try changing the setting it is in... or mabey it is in macro which is for close up shots.
Nov 11, 2009 | Canon PowerShot SD600 Digital Camera
Left camera in hot car, pictures are now blurry.
no you have built up moisture inside unit. use a hairdryer to get the moisture out.
Jul 09, 2009 | Cameras
FUZZY & BLURRY PICTURES.
It could be the focusing, did you check the focus every time? A slow shutter speed also causes blurry pictures. I know you do use your tripod, but if you don't use the self-timer function or a shutter cable then you are not using the tripod properly. Also, check the front piece of glass in the lens, clean it if it has stains or whatever on it.
Mar 28, 2009 | Kodak EasyShare Z1015 IS Digital Camera
My screen shows a blurry picture and it takes a blurry picture. it didnt used to. what is wrong? how do i fix it?
I have the exact same problem. When I was in NY last fall, suddenly my camera would only take blurry pictures. I hadn't changed any settings or anything. I can get halfway decent pictures in Auto mode, but any of the other settings only take blurry pictures. Apparently a lot of people have this problem, but no one knows how to solve it...
Feb 28, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Pictures come out blurry
change your settings, set the image size to a higher number. and select "best" on picture quality
Nov 24, 2008 | Cameras
98379 Sakar Digital camera
The crop setting you selected & used may be too low in size and resolution which is meant for web application.
Mar 30, 2008 | Sakar 90379 Digital Camera
Picture edges blurry
There is a setting labeled cropping... turn it on.
Nov 19, 2007 | Olevia LT32HVM 32 in. LCD Television
Blurry Pictures
Check that you have not got Macro set accidently.
If lighting level are low and the camera is selectinging a slow speed - reset to Apeture Priority -setting 'A' and and be very gentle with the release - the slightest movement will blur an image on long exposure.
Try these thing and if still introuble come back with more detail
Nov 11, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Cameras Logo
24 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
