Question about Vacuums
Need a replacement drive belt for my hoover lark u4043 not sure about last no. it's an old machine, but this one is in perfect condition, minus the drive belt. my local vacuum specialist says they can't get them anymore. where can I get one or a suitable alternative?
  • 328 Answers
Hi
As you know the Hoover Lark was more or less a rebodied Hoover Junior. The U4043/ (are you sure its not U4034?) model should use the same round drive belts as the Hoover Junior 1346 so youre looking for the old rubber ring type belts which are circular rubber rather than the flat types (usually ribbed) for the later 1980s U1104 series. You can find these types almost anywhere these days as these cleaners go on for ages.
Posted on Apr 19, 2008
I keep having to replace the belt on my Widepath Hoover Temp. Last time, the belt wasn't broken but had come off the spool. How can I secure the vacuum belt and/or stop it breaking? Thanks for any...
First be sure you have the correct belt for the machine. The current belt may be stretched, but not broken. The correct belt is # 38528033, or in a package of two, the package # is 40201160. When you have the agitator out of the vacuum, stand it on end and make sure it turns easily. If it does not spin freely, there may be hair or string in the bearings which will need to be cleaned out.
Jun 21, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Brush wont spin, belt is perfect
It sounds like the motor that spins the beater brush is burned out,If it is under a yr old it should be covered by the manufacturer warretee. Find a Hoover service center that does warrentee repairs.
Jan 25, 2010 | Hoover U8188-900 Bagless Upright Vacuum
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
How do I replace the drive belt in the hoover u6401?
Remove the plate from the vacuum's underside. You will see fourscrews or two clips that attach the plate to the vacuum. Removingthe plate will give you access to where the belts are running. Remove the old belts and replace with new belts. The hoover self-propelled models use two different belts. One is a flat belt Hoover #38528035 and the other is a V belt Hoover #38528034. You can find these belts at www.vacbelts.com on these pages:
http://www.vacbelts.com/hoover-38528035-belt.htm
http://www.vacbelts.com/hoover-38528034-belt.htm
Oct 14, 2009 | Hoover Vacuums
On my Hoover Savvy U8174-900 on carpet setting, the brush spins when I pull the vacuum towards me, but stops when I push it forward. Belt is tight and fine.
Hoover savvys have two very common problems that cause this. The first and most obvious is the belt that you checked already. Many times the belt is tight but those particular belts have teeth and should you lose any teeth on the brushroller OR the belt it can cause this.
The other problem this is a symptom of is a bad switch in the handle. It sounds odd but the switch assy in these machines controls 2 motors, one that causes vacuum another that causes the belt to turn! Often time that switch assembly is bad and the smaller motor that drives the belt does not run when the handle is in a certain position. This causes your brush to stop but since the louder bigger vaccum motor is still operating you never hear the small one quit. I would run this again and listen for a difference in sound. In this case you will buy a replacement circut board that is installed in the handle (i usually replace the entire handle assy, the small extra cost is worth the dependability as nobody can seem to determine for sure what makes them go bad)
You can get the parts from any hoover service center, use their dealer locator to find the nearest one. Be sure to take the old parts in and compare when buying new, hoover makes running changes to their product so 2 machines with the same model number can be different.
Aside from a stray bad or pinched wire you're more than surely dealing with one of those two items. I'd focus on the first paragraph as that is by far most common and least expensive.
Best of Luck!!
Jun 09, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Need drive belt
I'm guessing you have a hoover self propel windtunnel. If that is the case then you should bought the V belt suffix 034 and Flat belt suffix 035. The belt numbers should be listed on the serial tag though.
With most hoover two belt systems there is a pulley that is supposed engage when you recline the machine and this will apply tension to the V belt and tighten the system up so that the brush will spin. If you hold it upside down with the bottom plate off, and release the foot pedal, you should be able to see it happen.
Occasionally that pulley gets stuck and on some newer models they are prone to breaking as well.
Make sure the machine isn't set to floors.
Good Luck
Nov 25, 2008 | Hoover Vacuums
Hoover Wind Tunnel V-Belt no longer turns brush
that is the correct belt what you dont see is a tension pulley that when the handle is released pushes on top of that belt giving it the tension it needs. try replacing the other belt, even if it isnt broken it could easily be stretched out ( all belts of that type should be replaced every year - even if you didnt use the machine at all ). if that doesnt work that tension pulley could be damaged you would need to take the bottom of the machine apart to fix that.
Sep 18, 2008 | Hoover U6311-930 Power Drive Bagged...
Hoover Vacuum model U4471 making a very strange noise and letting of a smoke smell
The Elite upright may need to have its drive belt checked. Check that the machine roller is still working. Then turn the vacuum off and locate the screws on the floor head by turning the machine over. If you remove a couple of screws the floor head will come off and you can check the belt. Usually old threads and hair can stop the roller bar from moving properly or may have got to the belt. Ensure that it moves freely simply by turning the roller with your hand. If it doesn't then its possible that the roller needs to be cleaned or the belt needs to be replaced. Drive belts are easy to get for most Hoover products; a smoke smell like burning rubber usually indicates the drive belt is about to give up or has simply snapped. Dont forget to rate if this solution has worked for you. Ty.
Jul 29, 2008 | Hoover Vacuums
Need to change a belt on my Hoover Concept One Power drive
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766023
Generic problem for all Vacuums
Posted by gentilly on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Hoover Concept One Power Drive Upright vacuum there are 2 belts, a drive belt and a power drive belt, always use the Hoover genuine belts and for the best cleaning always change you vacuum belts every 4 to 6 months for the best cleaning. !st, remove the bottom plate and cut off the old belts – then you need to lift up the one side of the brushroll that has the pulley side for the longer of the 2 belts and slide it on. Replace the brushroll, B4 you go to far remember which went on 1st, the power drive belt (smaller belt) or the brushroll belt, in either case hook the belt(s) onto the pulley 1st and then use a belt puller or a screwdriver with a hook or bend on the end and stretch the belt(s) onto the motor pulley and then track the belts in a straight line – do this on both belts. Once you have done this then replace the bottom plate. Check your owner’s manual in the trouble shooting guide to see if they also have suggestions or check with your local vacuum cleaner dealer in your area or contact the Hoover website or the Hoover factory cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Brush on vac
I don't know how old your machine is, but the belt should be changed at least once a year and you should check to make sure the roller spins freely. There are bearings at either end of the roller and they will become contaminated with dirt and hair after a while and will need to be serviced. A new belt will help, but won't last if the roller is in need of service.
Dec 02, 2007 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
98 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
