Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Sounds like the sterring wheel is striped
It just goes click click click when I turn the steering wheel to the right like it is striped but left turn is fine. Can you advise
Sorry I don't have a solution but have a similar problem. I replaced the steering pinion gear in hopes that would resolve the problem, but it didn't. The steering pinion gear is located at the bottom of the steering shaft and turns the steering gear. Looks like the steering gear needs to be replaced as well. The nuts securing the steering gear are accessible in the same area as the pinion steering gear. I am going to order a replacement steering gear and attempt to replace it.
Posted on Jul 25, 2010
  • Phillip Hacker Jun 10, 2012
    Im having the same problem with my Troy Built Super Bronco riding mower and I have replaced both gears and still had the problem. So after investigating this i have found that where the steering rod comes through the frame it has reamed the hole out, so there is now to much play allowing the gears to not line up correctly. I am now trying to fabricate a thin metal plate to slide up the rod at the frame to keep it from moving. Hope this helps.
Power sterring noise
Check your power steering fluid level. If low will cause unit to whine when turning left or right. If fluid level has gone very low you will need to bleed system. With car jacked up start engine and turn your steering wheel all the way left then right a few times. Good Luck Friend.
Nov 07, 2014 | Cars & Trucks
MY 72 SUPER BEETLE STEERING COLUMN MAKES A CLICKING NOISE AND WON'T TURN THE WHEELS FROM LEFT TO RIGHT
Sounds like you have striped out your steering box. I would start there as long as everything is hooked up as it should be.
Nov 28, 2013 | Volkswagen Beetle Cars & Trucks
Steering failure
sounds like the gear box or sterring rack went out have some one move the wheel look see what is moving and wha tis not
Aug 26, 2013 | Jeep Grand Cherokee Cars & Trucks
Have sterring problem cub cadet lt 1024
i have been finding the plastic bushing that holds the steering shaft down into the other gear breaks or wears out that a look there
Aug 13, 2012 | Garden
Can some1 help me? when i turn to the left/right my sterring wheel turns all the way around in a full circle
look under the dash there is a intermediate steering shaft the could have seperated it goes threw the fire wall and connects to the steering
Jun 14, 2012 | Cars & Trucks
I can not turn my ignition switch i turn the steering wheel and it lock up on me
Wheel pressure on the sterring column will prevent the key from turning to start position, Try turning the wheel hard to the left to release the pressure before turning the key to start . If that doesnt do it then try to the right.
Before turning car off make sure the wheels are straight or take your hands off of the sterring wheel before you turn your key to the off position.
Lots of luck Jack
Sep 17, 2010 | 2002 GMC Sonoma Extended Cab
The sterring wheel is in locked position and the ignition wont turn
"Jiggle" your steering wheel to the left and right while trying to turn the key forward.
Mar 18, 2010 | 2002 Jeep Grand Cherokee
Wheel turnd left OK Wont turn right, Get loud
THE GEAR ON THE SHAFT IS STRIPED OUT NEEDS A NEW ONE
Sep 05, 2009 | Garden
2004 pacifica popping/clicking sound
Take an look behind you front wheels,turn in your wheel,and turn off the car,there rubber boots that cover your CV joints,if they are crack,you will see grease/oil.when the cv joints go bad thats the sound your hearing.
Jun 22, 2009 | 2004 Chrysler Pacifica
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
788 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
