Question about Whirlpool LER4634J Electric Dryer
My dryer won't start on its own. It makes a humming sound. If I open the door hold the switch and help the drum get started it works.
  • 744 Answers
See the link below, then click on the picture and take a close look at Part reference #24 - these are drum support rollers. Yours may be worn out or partially siezed. This happens after several years. The diagram may not be exact for your model but should give you a pretty good idea of what's going on. If you do elect to change the rollers, they should all be changed, not just one. You might want to take this opportunity to also check the belt and the belt tensioner near the motor.
http://www.apwagner.com/index.php?main_page=model_lookup&model_num=LER4634JQ0&model_id=99943&diagram_id=208168
Posted on Jul 09, 2010
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Oct 02, 2011 | Kenmore 63942 Dryer
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
The dyrer will not turn on. The dryer makes a humming noise but will not turn on.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Also, check the blower on the dryer to see if a article of clothing may have gotten stuck there and preventing the motor from running.
Jan 22, 2011 | Whirlpool Dryers
Dear Expert, When I went to turn on my Roper dryer it made a humming sound for a few seconds then quit, without out the dryer ever starting. I then had my wife depress the start know while I held the...
check and see if there is any thing in the dryer vent if not.open the door hold the door switch in like the door is shut.have your wife push the start switch in and turn the drum counterclock wise if it starts then the motor has gone bad if it hums still its still the motor.if it does start stop the dryer and try restarting several times sometimes they get a dead spot and it may work for years or may die tomorrow but these are a couple of things to try good luck
Dec 19, 2010 | Dryers
DRYER HUMS WHEN CNTROL KNOB IS PRESSED & MOVES SLIGHTLY..IF HELD IN TOO LONG IT BKICKS BREAKER. MODEL#HYE3658AYW
Greetings,
This sounds like the motor is bad, or going bad...I would have someone help you try and start it....open the door and hold the door switch in and keep holding the door switch while pushing the knob to start it and at the same time....have someone try and turn the inside drum usually, counterclockwise and see if it takes off....if it does...let go of the start switch up on console(timer),
but keep holding in on the door switch to let it run for awhile...you can shut the door real fast and it should keep running... if none of this works and it still will not start and just hum...the motor is bad
Dec 08, 2010 | Maytag Dryers
Start problem
Hi,If you hear the hum while you are pushing the start button and when you let off the button the hum stops, you have a notor going bad.
If you can get someone to help you, open the door, hold the door switch in, while someone else holds the start button, you try and turn the drum with your other hand. Sometimes the motor will start but, this only confirms the motor is bad and needs replaced. I hope this helps.
Thanks
Vic
May 15, 2009 | Dryers
Maytag dryer mod #mde600ayw only makes a humming noise when start switch pushed will not turn.
a hum with a burning smell means the motor winding has failed.
you can try this: open the door and hold in the door switch, have another person hold the start button. You manually roate the drum by grabbing a fin and moveit while the unit is humming.IF the dryer starts, you need a motor.
Good Luck!
Feb 28, 2009 | Dryers
Whirlpool LER4634J Electric Dryer Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
