Question about Mr. Coffee TFTX85 Coffee Maker
Water does not come out ...is there a fix - Mr. Coffee TFTX85 Coffee Maker
    Genius:
  • 1,970 Answers
Mcdevito75 here, Make sure everything is set to make coffee, New or clean filter, filter basket set in machine. Your coffee maker might need cleaning also.------------ Fill resovoir with white vinegar, let it run thru the machine 3 times, half way thru ther 3rd time stop machine and let stand for 30 minutes. resume brewing, then fill resovoir with water and let run thru machine 2--3 times to get rid of vinegar. If this don"t help you may need new coffee maker.
Posted on Jul 09, 2010
Water also comes out behind dispenser when used. Could this have something to do with water filter?
How to fix GE Refrigerator Frozen dispenser or water line ...
? 3:00
https://www.youtube.com/watch?v=52OfpE8zENA
Jan 10, 2012 - Uploaded by doublewide6
How to fix the frozen water dispenser on the GE refrigerator, How to fix, How to repair Ge refrigerator. You have ice, but nowater coming out the ...
Nov 06, 2015 | Refrigerators
How do I fix Hardie hot water system C32 that is hissing and leaking?
get a plumber to replace it . old systems are not efficient nor worth the time and trouble to try and fix. SORRY
Feb 16, 2018 | Water Heaters
Water is over flowing and coming out over the top of my hot water heater, i shut the water off and turned the temp down and turned the water back on after a few hours and water still is over flowing over...
If pipes are leaking, then that can be repaired.
If tank is rusted out and water escaping from the tank, then turn off the water plus power to the heater for safety, and then replace water heater.
Rusted water heater can be welded for repair, but remember that hot water is under pressure and tank can rupture any time.
Safest course if to replace heater.
Open following link for leaking water heater checklist:
http://waterheatertimer.org/Leaking-water-heater.html
Jul 27, 2011 | Whirlpool Water Heaters
Got storage heating and hot water tank .lights on cotroller to heat water but not heating water
1) You report that your tank-type electric water heater has lights on the controller.
Please look at label on side of tank to get brand and type of water heater.
Add a comment with all information you have, including description of product.
This will let expert possibly find a manual, and read manual alongside you to assist as you fix water heater yourself.
Keep in mind that expert cannot see your water heater, and that many things cause water heaters to malfunction, and that troubleshoot section of product manual is good place to start.
2) Search manufacturer's website for product manual so you can fix water heater yourself.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) If you have electric water heater and don't want to add a comment with identifying information, then look at following page for do-it-yourself troubleshooting:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
4) If you have energy smart water heater, you can access information and manual at following link, and possibly fix water heater yourself:
Product manual link shows on page, and gives phone number.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
5) If you do not have tools or know-how to fix water heater yourself, then call a plumber.
Plumbers are expert at fixing water heaters.
6) Post question of professional water heater forum, to double check anything a plumber, friend, or fixya expert says:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Element 2000W 8" WATER HEATER ELEMENT
I drained the radiator to put in fresh water water came out black
You should be using Antifreeze in the coolant system cause it boils at a higher temperature and
will not evaporate.plus rest protection and lubrication for the water pump. Water will rust the water jackets inside the engine and ruin the cylinder head gaskets .I suspect the leak is either a simple fix like a hose or water pump seal a big fix like a cylinder head gasket. Water can cause all of these problems.
Jul 03, 2009 | 2004 Dodge Stratus
Has anyone successfully fixed his or her water dispenser?
I have had a few where the water switch housing that holds the switch breaks and does not allow the arm to hit the switch to turn water on. that is one thing it could be ethier way not to big of an expence to get fixed
Feb 23, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Water keeps dripping after it dispenses water thru the door
When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
Since all this is inside the door, you will either have to take it apart to see/fix/replace.
Quick fix: turn down the water pressure coming in(?)
Call Mr. Handyman to fix.
If under warranty - they might fix this for you for free
If this is a factory defect, there might be a recall in place for repair/replacement parts
Googlee both - Make/Model + Dripping Valve + Recall
Good Luck!
Jan 17, 2009 | Frigidaire FRS3R5EMB Side by Side...
Mr. Coffee TFTX85 Coffee Maker Logo
396 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
