Question about Canon 75-300mm f/4-5.6 III USM EF Lens
Error 99 I have a 75-300mm zoom that i used with my 300v and it works perfectly. Now i have a 400d, often when i take pics error99 appears on the camera. It does take pics but not the settings that i want, the pic is too bright. How can i sort this out?
  • Anonymous May 15, 2008
    error 99 can anyone help
The possibilities are.. 1)the lens doesn't fit with 400D, i hv experienced it.I use a lens on my friends camera,it turn out find,but on my camera, it says error99. 2)Maybe the lens is broken,maybe the aperture wire.
Posted on May 20, 2009
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 51 Answers
I had the same problem and i found this guide online fixed my problem
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
Posted on Jan 29, 2009
Error99 appear on lcd
clean the lens contacts and body contacts with lens and try again. Otherwise send it to a technician for a service.
Apr 06, 2010 | Canon Digital Rebel / EOS-300D Digital...
I have a canon eos450 that showsan error99 when on automatic. It seems to be related to the flash being released when going to use the camera. I is fine on the other functionsPV AV etc but not where the...
Error 99 is a generic error code and only Canon can diagnose it. But given that it occurs when the flash is set on, it must mean there is a fault with the flash circuit. You may need a technician to replace or repair the circuit. Alternatively, you could purchase an external flash if the first option turns out expensive.
Mar 29, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Very blurry pictures on a Cannon Xti 400D
If u had took photo in very low light, pictures will appear blur. Or if you use tele zoom, u need to use tripod to stablize. In normal conditions, you can turn on image stablizer.
Feb 12, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Canon 400d DSLR error 99
Hey cookie8,
According to the manufacturer you should try cleaning the lens contacts, which I usually use a rubber eraser to do this. If this doesn't work try removing the battery, and if it's not charged charge it then reinsert the battery. If neither of these options work I would have the lens looked at by an authorized service technician, and of course if there is something wrong with the lens and if it's new you might be able to exchange it for a new one thru the retailer you purchased it from and if not it should be covered under the manufacturers warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 29, 2008 | Cameras
Pics are blurry
Have you changed the settings in the camera? When are you getting this problem? Is it when you try to shoot in low light?Does it appear like the pictures are shaken or is it out of focus? If they are shaken, use a higher ISO to shoot. If it appears out of focus, first check the lens for some smears. Clean the lens with a clean dry cotton cloth.
Check if there is fungus on the lens (this appears like spider's web or crack marks). If there is fungus, or you are still getting pctures blurred, take it to an authorized service center.
May 07, 2008 | Olympus Camedia C-2020 Zoom Digital Camera
Error99... pls help!!
here is a link for further steps to take on Error 99: Canon info
The article refers to the 30D, but the same troubleshooting will work for your camera too
Feb 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon error code 99
Your camera performs a quick 'integrity' check before each shot and goes into error 99 mode if the lens in incompatible or has a diaphragm problem. ( it will also display e99 if the shutter or flash unit is not ok but this does not apply here ). This is how you can check whether the diaphragm mechanism is ok : attach lens to your old camera and set camera to AV and set F stop to 16 . open back and release shutter and look through the back to see if your lens is closing to F 16. If it is closing fine then the lens is ok but is not compatible with your D400.
Sep 10, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon 75-300mm f/4-5.6 III USM EF Lens Logo
315 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
