Question about Hotpoint RVM1535MMSA Microwave Oven
No power hood light grounded out /now it wont come on/ does it have fuse that can be replaced inside
  • Hotpoint Master
  • 9,085 Answers
Depending on the brand and full model number, it may.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download many brands' mini-manuals here.
Sometimes the problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with aone year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Posted on Jul 11, 2010
Ge hood insert zvc36l1ss fan comes on by itself. When not cooking?
The switch is bad. That makes it a possible fire or electrical hazard.
You should replace the switch immediately, or at least turn off the breaker that supplies power to the unit.
Don't let a broken $20 part be responsible for burning your home to the ground, fix it!
Parts for this hood are at http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Range-hood-Parts/Model-ZVC36L1SS/0432/0122400
This shows you how to open it up and replace the parts: http://www.searspartsdirect.com/partsdirect/user-manuals/9235/ZVC36L1SS-GE-Parts-RANGE+HOOD-manual?pathRender=fromManualTabPage
Jul 26, 2014 | Microwave Ovens
Hood light & exhaust fan not working
You have no power to the unit. Breaker is out or the hot wires into the hood has come apart. The wires coming into the unit usually terminated in a junction box next to the fan housing.
Teas it for power an/or reset breaker.
Oct 21, 2013 | Whirlpool GH5184XPQ Microwave Oven
Kenmore microwave hood combination, The fan wont
With the full model number, chances are we could have helped you more.
If the cooktop lights recently failed, it may need circuit board repair.
Or it may be a failed hood TCO.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Microwave Ovens
With the full model number, chances are we could have helped you more.If the cooktop lights recently failed, it may need circuit board repair.
Microwave VENT fan keeps running
I would say you replaced a good hood thermostat (or "TCO" / thermal cutout) with a new thermostat of the wrong type.
The oven cavity TCO and the magnetron TCO will read zero ohms continuity when tested.
They are "normally closed" devices.
But the hood vent exhaust fan's TCO is a "normally open" TCO or thermostat, so it should read open or "infinity" on a continuity check.
If the temperature under the microwave gets too high, the hood TCO opens, which turns on the vent fan until it cools back down.
I would bet that only your fuse was blown.
May 18, 2013 | Microwave Ovens
I have the Kenmoore Microwave Hood 721.80402. During this last wave of storms, I was without power for 2 days. Once the power was restored, the microwave will not work. Everything is plugged in and the...
You might try pulling the plug on the unit and leaving it overnight. The electronics may have locked up due to irregular voltage during the failure. There may also be a GFI (ground fault interrupter) on that circuit that has tripped for the same reason. Check the kitchen outlets for a tripped GFI.
Feb 14, 2010 | Kenmore 62622 Microwave Oven
Hello; I have an AirKing Valecia 755 range hood. I dissambled it in order to remove a birds nest and clean. When I reassembled and installed the hood, it now does not function. No fan or lights. I...
Check and make sure green is ground,any metal.White,and black are hot,check them with a volt meter,make sure they are on the right sides of the switches.
Nov 20, 2009 | Microwave Ovens
Hi I'm thinking of getting an OTR mictowave and was wondering if I have to install an outlet in the cabinets or can I just place it where the existing wires for the hood fan are. This location would be...
The outlet needs to be in the cabinet above. The microwave needs a dedicated circuit. Turn the power off to the hood and see if any lights or outlets go off on the same curcuit. If only the hood is on that line your good to go with that wire if it meets requirments. Our code asks for 15 amp breaker and 12/2 grounded wire. If it meets your local requirments, just take it up inside the wall to your new outlet location(usually there is enough wire to reach) and install a box, outlet and cover.
Jul 23, 2009 | Microwave Ovens
Hood Lights not working
The problem lies in the circuit board / control panel. We regularly repair these control panel assemblies nationwide for 32.50.
Oct 06, 2006 | Sharp R-1610 Microwave Oven
Hotpoint RVM1535MMSA Microwave Oven Logo
121 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
