Question about Garden
Running fuel lines on s31bc snapper line trimmer how to
  • Roy Cagle
    Roy Cagle Jul 10, 2010
    Does this unit have the primer bulb on top of the carb or an externally mounted primer bulb? Either way, it's not real hard to do.
4 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
  • 165 Answers
SOURCE: I have a Craftsman trimmer mod# 358795121. What size fuel lines.
Sears has ample parts for repair.
Posted on Feb 27, 2010
On the Zero turn mower , how do you relieve the air in the pump lines after replacing a bad pump . Please advise.
How To Release Pressure From Fuel Lines - YouTube
? 0:51
www.youtube.com/watch?v=6oo9zlTMPOQ
Oct 15, 2009 - Uploaded by YeechBlitz
See a demonstration on how to release the pressure from fuellines of a 1997-2000 ... in the tank, but do not let the air out, so pressure can build up in there. ... Diesels is where you want to be extra careful, the injector pump to ...
5900748 Snapper Zero Turn Mower - Hammerwall
www.hammerwall.com/.../Snapper/.../5900748/Snapper%20Zero%20Tur...
Back To Snapper Tractors-Riding-Lawnmowers Model: 5900748 Snapper Zero ......Reinstall each mower blade with the air lifts pointing up towards the mower deck ... The fuel filter is located in the fuel line betweenthe fuel tank and fuel pump . .....TROUBLESHOOTINGTHE RIDER PROBLEM CAUSE REMEDY Enginewill ...
Sep 25, 2015 | Briggs & Stratton Snapper 5900748 355Z...
Engine runs then quits
You may have a small air leak at the carb, sometimes found at the bulb primer. This allows the engine to stop picking up fuel due to sucking air into the fuel line. If you re-prime, it will run again for a short period?
Apr 15, 2010 | Garden
Snapper SR130 riding mower won't start. Have
Is it getting fire to the plug, and is it a good blue flame. is the flame arcing between the electrode only. if not your plug could be fuel fouled. if it is fuel fouled toss it and get a new one. the wood ref key on the fly wheel may be bent . if it is bent it will throw it out of time. hope this helps
Mar 01, 2010 | Garden
Need help reconnecting fuel lines
One fuel line (the on with the filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The other hose comes out of the tank and goes to the bottom fitting on the primer bulb. A third section of fuel line goes from the top fitting on the primer bulb to the top fitting on the carburator. Hope this helped and best wishes.
Sep 01, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Have a snapper snap n' go trimmer s31sng - One of the fuel lines or more were cracked and It quit running - replaced all fuel lines but don't think I reconnected them correctly. Do you have a diagram of...
I am not really sure how many lines you replaced. But the fuel line layout on most types of trimmers, weed wackers and lawn mowers are pretty straight forward. There is usually a line inside the gas tank for connecting the fuel strainer\filter. Then a line from the bottom of the tank to the carburetor. This line may also have a fuel filter located on it. On more complicated equipment you may find a breather line that loops back to the carburetor.
Below are a couple of links that might be helpful. The first three are diagrams of a similar 31cc Snapper trimmer and links to other Snapper trimmers. The fourth is to the users manual for your trimmer.
Hope this helps.
http://www.partstree.com/parts/?lc=snapper&mn=311+31cc+Straight+Shaft+Trimmer+Series+1&dn=6600
http://www.partstree.com/parts/?lc=snapper&mn=310+31cc+Straight+Shaft+Trimmer+Series+0&dn=6597
http://www.partstree.com/parts/?lc=snapper&mh=19
http://dl.owneriq.net/a/a3fbde0d-dc76-4963-935f-821589699385.pdf
Sep 01, 2009 | Troy Garden
Need carb screw settings
Hi try setting the screws at 1&1/2 turns out from the closed position and go from there.
Aug 30, 2009 | Garden
My Snapper S31SNG will not start after replacing carb.
A short fuel line leading from the primer bulb should be placed just inside the tank. This line may be larger than the other fuel line depending on your trimmer, so make sure that you have the correct sizes. The small plastic piece goes at the end of the fuel line to prevent it from pulling out of the tank. It also serves as a overflow. Cut this line a little longer than you need it until you get it in the correct position. (Hint: You may want to taper the end of the lines before putting them in the holes, it makes it much easier to feed them into the hole, then square them up after they are in.) The other line goes to the bottom of your tank with a small filter at the end.
May 21, 2009 | Garden
Garden Logo
403 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
