Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Coffee maker seems to overflow sometimes w/ coffee and grounds
I soaked all parts in vinegar and water, still overflows and grounds mix in w/ coffee?
    Genius:
  • 1,970 Answers
Mcdevito75 here, Best Bet Look for an appliance repair shop in your area. Also make sure the filter is seated in the machine.
Posted on Jul 09, 2010
Why does ground flow from the top of brewer instead of coming through the dispenser?
Buy a new K-cup holder from amazon.com. Its the black cone shaped holder.
Jan 11, 2013 | Keurig B70 Coffee Maker
Coffee grounds "overflow", get grounds
The problem is the spring on the Sneak a cup feature is too strong and pushes the basket up thus shutting the valve off and causing overflow.Just pop that thing right off! Problem solved! Works like a charm 100% of the time no matter what type/grade of filters and even if you get 2 stuck together......."Sneak a Cup"? Some things in life are worth the wait!
Jun 12, 2011 | Black & Decker Coffee Makers & Espresso...
My coffee filter for my Keurig, seems to overflow. Making coffee is fine with the pods, but not the filter with which you can use your own coffee... I have tried different types of grinds (ex. fine,...
I have had this same problem when all of some of the coffee is ground too fine. It needs to be the correct particle size and if it is too fine, it will clog the screen and either overflow or not flow at all. Look at the ground coffee you use and check to see if it is uniform size or there are a lot of very fine grounds mixed with the coarser sizing. Try asking a coffee shop to grind you some coffee specifically for your Keurig cassettes. Most pre-grounds drip coffees are too coarse and many grinders in the stores where you grind your own whole beans do not produce a uniform size. I have an OEM Keurig cassettee and two generic cassettes and the screens have different pore sizes, with the Keurig being finer.
Aug 24, 2017 | Keurig Elite B40 Coffee Maker
I have a cuisinart dgb 650 series coffeemaker and the carafe top is partially clogged resulting in coffee spilling over the top of the canister. How can I disassemble the lid of the carafe to clean it?
Unfortunately the lid is one unit. What you can do is try decalcifying the lid by soaking it in a water/white vinegar solution. If that does not work you might have to purchase a new lid.
Nov 11, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Every few weeks, my 4-cup Starbucks Barista Quattro coffee maker overflows. It seems that the water either flows into the basket too rapidly or out of the basket too slowly. The basket overflows, and...
If your in a hard wayter area the basket overflow valve may be need cleaning. Fill with white vinegar and run a full cycle. Rinse by running 2 or 3 cycles with clean water. You may need to repeat the vinegar cycle if the problem persists.
Oct 16, 2010 | Starbucks Barista Quattro Coffee Maker
Coffee overflows onto the counter from time to time. Have a clean gold filter. It seems that the coffee doesn't flow threw the lid as fast as it used to. How do I clean inside the coffee pot lid? There...
I believe your problem is the filter basket holder is not seated correctly or the carafe is not completely inserted in the unit to push the brew pause lever up. The brew pause feature which stops the coffee from going into the carafe when you want a cup of coffee before the brew cycle is done. When you remove the carafe a spring lever stops the coffee from dripping into the carafe. When the carafe is inserted it must push the spring lever up to allow the coffee to flow into the carafe. If it is not the coffee will overflow and make a mess. The filter basket holder should be firmly seated in the unit so it will not have any play in it. Cuisinart recommends using a vinegar and water mixture but BrewRite Cleaner (Sodium Carbonate) available in the coffee section at Wallmart, Kamart and Target is fantastic. You can clean your carafe with BrewRite Cleaner and hot water by letting it soak a few minutes and rinsing. I will also clean your filter basket holder by soaking it as well and all your coffee residue will be gone with no scrubbing.
Jul 29, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee grounds overflow
Tressia,
An overflow can occur when using certain brands of coffee that are finer ground or using a water softener, bottled water, reverse osmosis, or filtered water. If you will call Bunn Customer Service, you can get a flow restrictor sprayhead which will eliminate this issue.
May 08, 2010 | Bunn NHB Coffee Maker
Water not filtering quick enough, basket overflows
Make sure your sprayhead is the proper one (5 hole) and in good shape. Also make sure that the hole on your filter basket has not been partially closed. This can happen if you set it on the hot warmer. As a last resort, you can slightly enlarge the hole in your filter basket.
Apr 28, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Error message states no water, but there is...
Unplug the device and plug back in after 1 min. If it still fails, then you have a dirty water level sensor or the control circuit board is fried. Empty the water out and fill it with vinegar as full as you can without overflowing. Let it soak overnight and turn the machine on (without coffee in it). Turn off after 30 secs.Turn on again and allow it to finish the cycle.  Discard the vinegar. Run three more brewing cycles with water only and it will be OK to use. If this does not cure it, then the only cost effective way is to replace it.
Apr 26, 2009 | Krups FME2 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
413 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
