Question about Hardware & Accessories
Utilitech 1 outlet timer tm01dhbl how do i program it to turn on
Just bought 2 of these things. I can't figure out how to set "on" either, and I have called Utilitech twice (left messages) and left an e-mail. So far, no answers. Let me know if you find a solution, or they go back to the store.l
Posted on Nov 03, 2010
Utilitech 2 outlet timer - 0155671
No.
Each outlet has same on-off programming.
Utilitec does not make 2-channel timer.... and neither does any other consumer timer company... unless you buy a box timer like Intermatic ET 1100 or 1800 series etc 2-4-6-8-12 channel timers.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
To have 2 different programs from same outlet, then buy 2 bar timers that both fit same outlet, and then program each to suit need.
http://waterheatertimer.org/Woods-timers-and-manuals.html#bar
Many bar timers are 24-hour instead of 7-day.
Gene
h
Sep 22, 2013 | Hardware & Accessories
I have a Utilitech one outlet light timer and I can't get it to work! I've never had a problem with a light timer; they're pretty straightforward in how to use them. I set the current time,...
Thank you for including model number.
TM01DHBL is typical analog timer with 1/2 hour segments located around edge of dial.
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#59366
There are no repairs for defective timer: Here are suggestions.
1) Locally purchased timer has longer warranty period since you can buy same timer later and return defect in new package.
2) Top of timer has slide switch. Most analog timers have 2-or-3 position switch that offers override capability. Set some segments, move slide switch each direction, and then manually rotate timer dial clockwise two full revolutions to watch how lamp turns on-off.
If lamp does not turn on-off with switch in at least one of the slide-switch positions, then timer is suspect.
3) Always a good policy to test outlets with cheap circuit analyzer to check for electrical abnormalities that can affect timer electronics.
Since this is mechanical timer with simple electric clock motor, chances are that reversed polarity will not immediately affect timer.
4) Put timer on a different outlet, controlling a different load, and see if problem is the same.
5) Make sure segments are pulled all the way up.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | Hardware & Accessories
I have an utilitech outlet timer #tmo1dhbl and I am having a problem with setting the time can you tell me what to do? Thanks
My files show Intermatic TM01DHBL is 24-hour analog dial timer with 1 grounded outlet, and a switch located on top of timer.
http://waterheatertimer.org/images/Woods-59366-image-500.jpg
This timer has segments that raise up:
http://waterheatertimer.org/images/Raise-segments-240.jpg
Open following link for setting information:
If this is not your timer, then add a comment with clear description of timer.
Aug 12, 2011 | Hardware & Accessories
How to program utilitech 1 outlet daily timer
Do you have the Utilitec number?
Add a comment with description of timer I can help.
I own several Utilitec timers.
Following link shows programming for 4 different Utilitec timers;
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Dec 01, 2010 | Day-Timer Hardware & Accessories
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
How to program utilitech 2 outlet timer
Push all the pins down. Pull them up for on/off times. Set the clock by turning the dial to current time. Plug it in. Plug timed items into timer outlets. Warning: Both outlets will turn on and off at the same time.
Dec 16, 2009 | Green Air Hardware & Accessories
How do you program the utilitech 1-outlet daily timer
How do you program the Utilitech Outdoor 6-outlet Stake Timer
Dec 01, 2009 | Day-Timer Hardware & Accessories
How to program utilitech 2-outlet timer
I bought a Utilitech #0192775 self-adjusting wall timer to regulate some window candles. I want to simply set it to come on from dusk to dawn, and have followed their directions the best I can. However, it does not work. Even some of the steps in the instructions are not on this model, so it is impossible to follow their directions to the "t". Do you know how to get this wall-timer to do what it says it will do? Thank you!!
Nov 22, 2009 | Hardware & Accessories
Hardware & Accessories Logo
1,464 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
