Question about Acer TravelMate 4652LMi PC Notebook
My note TravelMate 4652LMi doesn't work. The display didn't work so i used a external LCD display. It works for some time but now even so there's no result.
  • 487 Answers
Hi, sorry but it isn't good news, sounds like your graphics card has gone. If you can get it working with another monitor, go to control panel, system, hard ware, device manager and check for any recorded problems with the graphics, vga. If there is a problem it may be marked with a ?, right click hear and try updating your driver. Hope this helps, regards
Posted on Jul 09, 2010
Monitor is dark. how to fix?
Walt, hold the Fn key down again, and tap once more on the Acer, F5, Display Toggle-Over key.
There are at least 3 display options available;
1) Internal display of laptop ONLY
2) Internal display of laptop AND external display
3) External display ONLY.
Were you just using the external display for more 'display real estate room', or was/is there a problem with the internal display of the laptop?
Was no problem? Is now? Even when using the guidance stated above for the Fn and F5 key?
Then if your laptop uses a CCFL for a Backlight, it also uses a screen Inverter. Screen Inverter is bad.
If it doesn't use CCFL/s for a backlight, and uses LED backlighting, replace the LCD screen.
The LED backlighting is incorporated in the LCD screen assembly, and you ain't replacing it.
Replace the entire LCD screen.
Post the laptop manufacturer name, and model number in a Comment. Model number is on Bottom of laptop.
Try to hurry as I'm going to a meeting with the head of General Motors, (Obama), and later with Bill Gates.
OH I'M JUST KIDDING!
Regards,
joecoolvette
Nov 14, 2012 | Computers & Internet
My notebook is acer travelmate 4000. I connected the external monitor with vga port but the result is blue on external lcd TV. I did the step for display setting but I could not find the dual monitor in...
Please try to configure to the graphic Properties.
found at the task bar or at the control panel.
Enter to the device and set use Multiple Display.
This feature available to the Inter (R) Extreme Graphic.
Jul 13, 2011 | Acer TravelMate 2300 Notebook
Hi ! i have dell vostro 1510 and which is not booting up. even the bios is not showing up. Black screen appears and the loading lights blinks for 4-5 times then nothing happens. Power button is glowing...
- try to plug an external monitor on your laptop
- if you can see a screen on the external monitor, then you have a faulty LCD
- if you don't see anything on the external monitor, then you have a faulty motherboard
Jul 04, 2011 | Computers & Internet
When I try to turn the computer on, battery light flashes four times but computer will not turn on. This happens even when i have the plugged into the outlet
Hi nancy jac719,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 09, 2011 | Gateway M-1626 Notebook
My gateway laptop didn't start up,when powered on only black screen appears
Hi jeangray 17,
Hope this helps.
Jun 05, 2011 | Computers & Internet
The problem of my Acer TravelMate 3270 is no display in the LCD Monitor even the computer is power on & completely loading the OS. I tried to connect an external monitor thru the vga port but no...
Did you make any hardware or software changes in your computer after which this is happening?
Which is your operating system?
Do you see Black screen after os loads up? if yes then its a black screen error.
A black screen may occur if there is a problem with the video card drivers and Windows 7. To resolve this problem please follow these steps:
1. Restart the computer.
2. Press the F8 key before it enters Windows.
3. Select the Safe Mode option in the Advanced Boot Options menu and press Enter.
NOTE: If Safe Mode does not work please retry the first two steps and select the Enable low-resolution video (640x480) option instead. If this option is selected your desktop will be bigger than usual - this is by design.
4.
Once in your desktop, click on Start and select the Control Panel.
5. Select the Hardware and Sound option and then click on Device Manager under Devices and Printers.
6. Expand the Display adapters list - this should display the video card that is currently installed on your computer. Please note the make and model before proceeding.
7. Right click the video card under Display Adapters and select Disable.
8. Repeat this step if more than one video card is showing under Display Adapters.
9. Once all display adapters have been disabled restart the computer in normal mode.
At this point you should be able to get into your computer without a problem; however, your video card is disabled so you will need to download and install the latest drivers for it. If you had noted the make and model of card when you were in the device manager you can search for this on the internet and/or contact the hardware manufacturer for help. Once the drivers are installed correctly on the system you should be able to boot normally without any resolution problems.
Post back we will be happy to help you.
Hope this helps.
Cheers!!!
Jan 06, 2011 | Acer TravelMate 3270-6569 Notebook
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
USE EXTERNAL VDU
press fn F5 to switch to external display.
Mar 02, 2009 | Acer TravelMate 2300 Notebook
Fn F5 key in my Travelmate2310 stopped working
Was Fn+F5 working before? Why do you 'have to use with external display", because LCD no display any more or...?
If non above, you better check from BIOS and chang display to Both LCD and VGA.
If Fn+F5 was working before but not now, could be something else wrong... I need know more details....
Nov 12, 2008 | Acer TravelMate 2300 Notebook
Acer Travelmate 6291 LCD monitor problem
Your concern is a typical problem with LCD displays/monitors. There could possibly be three (3) reasons why it is behaving as you have posted.
1. Backlight/Inverter problem;
2. LCD panel problem;
3. Video card problem.
You can do initial diagnosis by:
a. connect the laptop to an external monitor. Using the Fn + F? keys, activate the external monitor to be the default display. If it works, you have eliminated the possibility of the video card having a problem. If it likewise did not display anything or blanks out after sometime, then you have just confirmed that it is the video card that is a problem.
If you have ruled out the video card (using above procedure), you can proceed determining if it is an LCD panel problem or backlight/inverter problem.
To determine if it is a backlight/inverter problem, run the laptop normally even without a display. Let it boot and run through its startup sequence even if you can not see anything. Using a flashlight, shine a light obliquely to the face of the LCD display. if you can see some semblance of your desktop albeit dark, then you have just confirmed that it is the backlight/inverter. If even with the aid of a flashlight, the display s completely blank, then it is possible that the LCD display panel is defective. In some cases it is the flexible flat cable that is at fault.
With any of the aforementioned possible problems, opening the unit is required. This would need familiarity with electronic components and circuitry, use of a DVM and perhaps even a soldering iron. Should you not be comfortable doing this, it would probably be to your best advantage to seek the services of a qualifiedly professional.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Computers & Internet
Acer TravelMate 4652LMi PC Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
