Question about Kohler Electrical Supplies
I have a Kohler 10kw diesel generator that start easily. However the HZ only come up to 45hz. I can bring up the RPM using the governor adjustment but this causes the engine to create white exhaust and unburned fuel.
  • 10,865 Answers
Hi. What you are experiencing is known as "wet stacking". Read on. A diesel engine is subject to "wet stacking" or over fueling if run for long periods of time with ultra light loads (less than 40% of the rated output). "Wet Stacking" causes the engine to smoke and run rough because the injectors become carbonized. Running a heavy load will usually clean up the over-fuel condition and allow the engine to perform properly. Diesel engines operate better and more fuel efficient when loaded (70-80% of the rated output is optimum); J.
Posted on Jul 09, 2010
  • telwaro Jul 09, 2010
    Thanks Jo. Will this also correct the low hz output as well? Currently 45hz. At 45 hz the gen will not start my air conditioner water pump. it simply viberates without rotating. Voltage is also down at 105VAC.
Frequency adjustment or solution
Can you check the RPM of the engine? 3600 RPM = 60 HZ. If it is running around that speed, try a different frequency meter.
If it was producing 180 HZ, it should automatically shut down and show a fault code!
Dec 15, 2011 | Briggs & Stratton Electrical Supplies
How do you adjust the idle on the Coleman 6250 Generator
There are many different models of Briggs used however simple methed is to find the governor shaft. Attached to the small shaft will be a lever with the governor spring and linkage that connects to the throttle. One end of the governor spring attaches to the lever and other is attached to either an adjustment screw with locknut or metal tab that can be bent. Increasing the pull of the governor spring on the lever will cause the engine rpm to increase. Bend the tab to allow for greater pull or adjusting the bolt with locknut. Make sure that the engine is not turning much more than 3600 rpm. Use a digital meter with Hz setting to set the output cycles at 60. When set at 60 cycles the engine should be turning about 3600 rpm which is where the engine develops max power.
Nov 09, 2011 | Coleman Powermate Premium Plus 6250W...
High voltage rpm power generator output
Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
Oct 10, 2011 | Coleman Powermate Powermate 5000W...
How to adjust a fuel governor for a 3750 watt coleman generator
With parts list in hand, look at reference #21 governor arm and reference 89/90 adjustment screw. This adjustment will increase decrease engine speed. I would use a meter with hz setting to set engine speed to achieve 60 cycles. Sixty cycles on the meter would indicate that the engine is turning 3600 rpm which is max. If all working correctly, voltage should be around 120v at 3600 rpm and 60 cycles. Good luck
Aug 02, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
1982 kohler in rv put in new brushs only putting out 96 volt
Try raising the engine rpm slightly. there should be a adjustment on the piece that hooks to a spring which is connected to the governor arm.
Mar 26, 2011 | Kohler Electrical Supplies
I have a briggs & stratton / Powermate portable generator; there is a lever with a black plastic handle on the end of it, right next to the 'choke - run' lever which has a red plastic tip on it. ...
The engine on your generator is also used for other applications some of which require an adjustable  throttle control. On a generator the engine must turn about 3600 rpm to obtain proper output of voltage and cycles. Upon further inspection of your throttle/governor you will probably find an adjustment consisting of a screw, nut or a tab on one end of the governor spring that can be reset for proper engine speed. (tab can be bent for more or less tension on spring) To check present governor setting, use a volt meter that has frequency setting. Make sure that generator is set to about 60 hz. (3600rpm) Good luck with your generator.
Aug 04, 2010 | Coleman Powermate Powermate 5000W...
No load voltage to high 132 volts on power mate 7500
Actually, without a load being connected, this voltage is within specifications. As you connect loads, the engine slows down, voltage will drop as well.
If your meter has the ability, the frequency of the generator with no load plugged in should be 65 or so (preferably 63, but hard to keep it there with mechanical governor).
If you do find that your voltage is too high, with a load plugged in, you are able to reduce it slightly by adjusting the governor ever so slightly towards a lower RPM. 60 RPM = 1 Hz, and a few volts difference.
The best way to adjust your generator is to plug in a load that is half the rated wattage of the generator. Then make your adjustments, keep the frequency just a hair above 60 so that additional loads won't cause it to drop too far.
Jun 12, 2010 | Coleman Powermate Powermate 5000W...
Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Apr 12, 2009 | Guardian Electrical Supplies
Porter Cable 5500w generator (10hp BS) will not regulate speed.
While attending college I worked at a tool rental center and learned a great deal about matching generators to customer requirements and troubleshooting customer owned units. There are simple tests that you can perform, however, first some info on what to expect from a generator. Most generators are overrated and under powered. You should only expect to get about 60 - 75% of rating. Example, a commercial honda 5000w generator has an 11hp motor that can only produce about 9.5 hp at 3600 rpm. If a customer needed 5000w of power, we would rent them an 8000w generator because as the generator is loaded to max the voltage will drop. You generator will probably only provide steady voltage ex. 115v at 60 cycles to about 3500w then voltage will begin to drop. New generators have automatic voltage regulator that varies the power to the armature increasing/decreasing the power of the magnet. These voltage regulators suffer a high failure rate and are expensive. If your generator is not giving you 3500 watt at 115v 60 cycles your engine may have a few problems and your power generator end may need tweaking. (I would not expect to achieve 5500w at 115v with briggs 10hp) .
The governor is about 2 inches in diameter and turns off the cam gear inside the engine. It is flyball type with two or three small arms that react to rpm. The faster the engine turns, more force is applied to the governor arm to reduce engine speed. Easy to test, with engine running use finger pressure against the arm to increase speed and you should feel a greater resistance as the engine speed increases. Another simple test, remove air filter to expose butterfly inside the carb. Move the governor arm and check that the butterfly opens fully. If it does not open fully linkage and governor is not set correctly. Next, start engine and load generator up to max and check that butterfly opens to full as the load increases. When the butterfly opens all the way under load the engine is at max. Add up the wattage of all the tools/appliances you used to load the engine to get an idea of max load . Lets assume that the shop adjusted the governor properly, if the governor was not working the engine would over rev. and damage would occur. As you were told the governor spring controls speed and can be adjusted somewhat by bending tab or adjustment screw. But a review of your generator manual or that series of briggs engine will show that there are several governor springs available and different placement holes on the governor arm to attach the spring that will change the power curve. Pulling on the spring can only do so much, however changing the spring to different gauge /turns/material or differnet location on the governor arm will cause the engine to perform differently. These springs are sold thru briggs dealers by part number for your engine. This would be considered tweaking to get a different power curve.
Now for the generator. Some generators have a capacitor incorporated in the windings. This capacitor must measure within 95% of rating. Remove from circuit for testing. Finally look very carefully at the commutator rings for any evidence of brush bounce. If the brushes do not perfectly seat you will lose power. If your generator is brushless you can only hope that the diodes are within spec. because it is too difficult to test them. They also must be removed to test. Finally if your generator has an automatic voltage regulator the only test would be to replace with a known good part. At the rental center we stocked spare parts so that we could quickly find fault. There is soo much to learn and the life too short. I hope this helps good luck, please email your questions.
Dec 24, 2008 | Coleman Powermate Premium Plus 6250W...
Generator wont put out enough voltage, only get 107 volts, is this a voltage reg. problem
This problem is either that the engine RPM is too low (most likely), or that there is something amiss in the voltage regulation. Get yourself a DMM that measures Hz, plug it into the output and see if you get 61.5 Hz, if not look for the adjustment on the governor spring. On some Powermates this is a screw that pressed on the governor arm, on others it's a little tab the governor spring attaches to that you bend. Do this at no load. FWIW 61.5 Hz is also 3750 RPM of the engine.
Oct 22, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
65 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
