Question about Sony Playstation 3 (PS3) Console
Trying to set up ps3 with a samsung tv getting error message mode not supported
  • Sony Master
  • 4,806 Answers
Make sure all leads are connected to the TV.
Next, turn the PS3 off so the red light is on. Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
That should have reset the video settings so you will be able to set the video settings again and access the PS3 menu.
Regards.
Posted on Jul 09, 2010
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
Trying to connect PS3 to Samsung HL-S4676S tv using HDMI cable. I get message saying mode not supported
So I had this same problem. I found that when I hooked to a 1080p TV my PS3 was working, however when I hooked to my 1080i it said Not Supported Mode. So I then hooked to the 1080p and told my PS3 to limit it's self to 1080i mode and hooked it to my Samsung TV and it worked just fine. Give that a try and it should solve the problem. Hope this helps.
Oct 09, 2010 | Samsung HLS4676S Television
Problem connecting my ps3 to my samsung le23r71bx tv using an hdmi lead. I get an error message "mode can not be supported"
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 28, 2010 | Sony Playstation 3 (PS3) Console
Cannot connect my ps3 to my tv. keep getting (mode not supported)on a black screen. anyone help ?
Check the supported modes in your user's manual for the TV. Check the output mode of the PS3 from its manual. Can you find any that match? If not, then you can't make it work....
Apr 23, 2010 | Samsung LE32R72B 32 in. HD-Ready LCD...
Connection error from ps3 to tv.
When you hit the power button from the console, hod it until it beeps at you twice and it will reset the video settings. I read this on a post from gamespot. I hope it works.
Jul 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Mode not supported error message
Either the video cable is messed up or you might have to lower the visual setting on the console.
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
May 14, 2008 | Sony Playstation 3 (PS3) Console
1080p high def issues
The HDMI cable I had originally wasn't a good enough quality. I purchased an HDMI v1.3 cable and everything works at 1080p. You don't need to pay loads for a cable, got mine from Play for £9.99.
Mar 29, 2008 | Televison & Video
Ps 3 no data
Try holding the power on button down until you hear a series of beeps, each one representing your ps3 switching video modes. try this until you get a picture on your screen, then you can use the options to set it to your tv's resolution. I've seen this same problem often from people holding the button when they turn it on :3.
Hope this helps.
Mar 26, 2008 | Sony Playstation 3 (PS3) Console
Mode not supported with playstation 3 DVI input
@ddkim From standby, press and hold the power button until you hear a second beep. this reset the display settings, and may work - Cheers JB
Dec 20, 2007 | Samsung DLP HL-P5663W 56" TV
Sony Playstation 3 (PS3) Console Logo
237 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
