Question about Kenmore Elite Oasis 27052 Top Load Washer
How to take top off to reach lid switch on a Kenmore 110.15962401
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.15962401&pathTaken=partSearch
Next, see the following for how to release the console and remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=746900826707e36832e6985d3e3c376b
NOTE:
Some Sears washers do not have removable end caps (the screws to release the console are under the caps.)
If yours is this type slip a thin putty knife under the ends of the console and you should be able to release the spring clips holding the console on.
You should be able to determine which type of console you have by looking at the diagrams on the sears site.
Posted on Jul 09, 2010
  • Takitapart Sep 03, 2010
    Exactly what I neeeded to know, and the links were the right ones I needed! Thanks!
I have a Kenmore top load washer, it filled with wather, however, will not do anything after that? Lid is closed and still won't agigtate, or drain
Your lid switch is bad. You should open the control panel, unhook the switch, cut and splice the 2 outside wires together (usually tan and grey colored - NOT THE GREEN ONE). Reinsert the plug, close the control panel and you'll be all set. Don't listen to anyone who tells you that you can't splice the wires - also known as bypassing the lid switch. I refurbish and repair appliances for a living and I warranty for life - I bypass these switches all the time. If you need help opening the control panel and/or doing the bypassing, you can reach me via email on yahoo - smms6776.
Jun 07, 2012 | Kenmore 24032\24036 Top Load Washer
How do you get the lid off to replace the lid switch.
remove the screws on each end of the control panel,some units you have to remove the end caps to get to the screws, then flip back the control panel it has plastic hinges so be careful,then you unplug the lid switch,remove the two clips with a screwdriver that hold the back on,open the lid and reach on the inside and pull the back towards you and lift off the base,replace the switch and reinstall!
Sep 02, 2010 | Kenmore 24902 Top Load Washer
Kenmore Mod# 110.25842400 lid switch
The following link gives you step-by-step instructions on how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions about this repair, please let me know. I hope this helps you.
Jul 15, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore washer somtimes won't go threw spin cycle
kenmore washers have a 2min. drain before it spines if leting it drain for 2min does not work u proberly need a new lid switch. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore top loader it will do everything except empty water and spin when it reaches this point nothing happens and there is no sound at all
Probably a bad lid switch. Open the control console and use a insulated jumper wire to jump out the lid switch connector and try the spin cycle. If it works, replace the lid switch.
If not, replace the timer.
May 15, 2009 | Admiral AW22 Top Load Washer
Replacing Lid Switch on Kenmore Washing Machine
Take your back off and reach in toward the front top panel there may be two screws holding the top down to the cabinet or the other way might be the top pop up but see through back first.
Apr 04, 2009 | Kenmore 24032\24036 Top Load Washer
Not spinning after wash cycle
remove the 2 console screws one on each side of front or they may be on the back of console,flip it up and you will see the lid switch jack on the washer in the middle,unplugon the washer side you want two cut the 2 outside and wire nut them together,this will by pass the lid switch,plug back in,put console back and you should be good to go-mike
Nov 02, 2008 | Kenmore 22422 Top Load Washer
Won't drain, rinse, or spin
That will be a lid switch problem
Nov 01, 2008 | Kenmore 22622 Top Load Washer
I think it is the same proble as you discribe
Hey chiki76
You still have a lid switch problem. The switch has to be replaced. The switch usually comes apart or the clips securing them are broken
regards
Sep 04, 2008 | Kenmore 22422 Top Load Washer
Have kenmore 70 series washer model #20702991 ser #1069231 type 111 will not drain. It starts the cycle by agitating then stops and will not go to drain cycle. switch on top lid does not ckick, tried...
The lid switch must close for the washer to spin. I've seen a lot of these break where it's mounted to the top. You may still be able to reach under the top to grab the switch to close it and get it to drain. You'll almost certainly need to replace the lid switch.
Jul 21, 2008 | Washing Machines
Kenmore Elite Oasis 27052 Top Load Washer Logo
170 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
