Question about LG DLE2532W Electric Dryer
Our dryer is making a whining sound (almost like metal on metal) when the dry cycle first starts out. It goes away after a few minutes. Any ideas as to what's going wrong with it?
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerOur dryer is making a whining sound (almost like - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Jul 11, 2010
Kenmore dryer runs only for a few minutes
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Nissan pathfinder 1995 model SUV, when i try to start it its making a whinning noise then i hear a hard clucking sound and the whinning goes away without the car starting
Does the engine crank at all ?
The low whine could be the starter turning but not engaging the flywheel.
The clunk could be when the bendix gear on the starter makes contact with the flywheel.
If the starter does not have enough voltage, the solenoid or bendix may not engage. Even tho you replaced both the starter and battery, there could be a problem with the cables or the ground connection.
Jul 17, 2012 | 1995 Nissan Pathfinder
When we start the dryer it's stsrt making loud noise matal to metal then it goes away for few minutes and comes back
Hi bojanhadziki...
You could have a couple of problems..
1...The door seal may need replacing, making metal to metal contact
2...The drum rollers may need lubrication or replacement
3...The back bearing may need replacement or lubrication.
Please take time to rate me
Sep 26, 2011 | Kenmore Elite HE4 Electric Dryer
My dryer is squeeking and grinding, but not all the time. What could be wrong? When it first starts, it sounds like it is grinding, but continues to work. After a few minutes, it stops. Then it will start...
One of two issues is going on, or maybe both. The first cause for the grinding noise is going to be the main bearing that is bad, and needs to be replaced. The squeaking is actually coming from the belt. So I would check under the unit and make sure that you do not have any metal shavings under the unit. Then also check the belt
May 18, 2010 | GE DBL333EA Electric Dryer
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
2000 Jeep Cherokee Gear Grinding & 4WD Whine sound
Give a try by change your transmission/filters and Transfer case oil.
Oct 27, 2009 | 2000 Jeep Cherokee
I have a 2003 Hyundai Santa Fe V6 3.5L with automatic transmission. 48K miles. When I start the car after sitting over night, I hear this whirring/whining noise from the engine compartment. I goes away...
your whining noise might be comming from dry belts in order to pinpoint your problem have a jug of water ready before startup open the bonnet then startup if the noise appears pour water over the belts if noise goes away replace v belts
Jul 13, 2009 | 2003 Hyundai Santa Fe
Kenmore C11084 7029 0 dryer will not start
replace the main motor you have bad motor
Nov 12, 2007 | Dryers
LG DLE2532W Electric Dryer Logo
289 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
