Question about Dishwashers
Bosch sgs5312gb/07 dishwasher not getting hot - was stuck on rince mode - have got it off that setting - tried to use it - stays on wash and is not getting hot
  • wizzy wozzy Sep 10, 2008
    I have a Bosch SGS5312GB/12 dishwasher. The machine does run a full cycle but takes longer. I have noticed the water is not getting hot. I have tested the heater element and that shows continuety. Could the problem be a relay and where is it located?
  • ozziespice May 21, 2009
    Winkypot I have exactly the same problem. I've taken the front door panel off, think I've found the circuit board but what's the relay? Any tips on what I'm looking for now?
If you open up the control panel (access by removing the front door panel) you'll find a circuit board and the relay. I suspect you'll find that a solder joint on the relay has burnt out - if so, easy to fix with a blob of solder - good luck
Posted on Jan 11, 2009
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Why do i have a problem with my Bosch diswasher mod:she9er55uc/51 ...sanitize and refil rince are flashing when i start the machine
The rinse light is telling you the resiviore is empty and should be refilled the sanitize means that option is choosen try resetting options
Jun 25, 2014 | Bosch 800 Plus Series SHE9ER55UC 24...
E:25 on bosch dishwasher ?
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hot runningwaterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 09, 2012 | Bosch Dishwashers
I need a manual for a Bosch sgs5312gb/12 dishwashing machine
Download the manual from the link below.Click on search for manuals and type the model number i.e SGS5312.Click on selection to download.
www.boschappliances.co.za/
If any problem arises please inform me or send me your e-mail adress and I'll send you the manual.
Hope this helps.Thanks!
Jan 04, 2012 | Bosch Dishwashers
The dished appear to have a milky film on them after washed. We we use rince aid but it is not working. How de we get them sparkeling clean ?
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Daniel
Aug 07, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes wont rince clean
Hello Dennis, welcome to Fixya. There are several factors which influence how your Bosch perform's. Saying that brings me to a point I have to ask a few questions. 1) How long have you had the unit...when did you buy it ? 2) do the dishes always appear dry when the cycle completes ? 3) How long does the unit take to complete a "normal" wash cycle ? 4) Do you have adequate hot water going to the unit ? Let me know as much as possible and I should be able to help. I will watch for your response. Macmarkus :)
Jun 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher, model SGS6312GB/07. The water does not heat up so the dishwasher does not complete its cycle and remains in wash mode. The water has to be scooped out
press cancel/drain sequence to get water out-check owners manual.
2 possible solutions to your problem discussed here:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
problem may be a burnt out solder connection on circuit board
call bosch to see if it recall issue
Oct 30, 2009 | Dishwashers
Bosch sgs5312gb leak
More than the door seal, check the water level is not stuck down or sinking. If the appliance is leaking from the door, this is often because of overfilling. If the machine is not overfilling, then replace the door seal.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 04, 2009 | Bosch Dishwashers
The rince light stays on and it wont run, you cant get to any other cycle
hi there,
sounds like you may have a stuck key on the keypad. disconnect the power and check the keys on the keypad as well as the pin connector behind the keypad that plugs into the board behind it for any dislogged or bent pins. replug all connections and plug the unit back into the wall. this should fix the problem. if the problem persists, replace the keypad. i know what you are thinking, new unit right?
Nov 06, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwashers Logo
452 people viewed this question
Top Dishwashers Experts
