Question about Canon Office Equipment & Supplies
Error 5200 error code 5200 appears at time of print on a canon iP6000D
  • Canon Master
  • 4,737 Answers
This error code 5200 indicates that one of the cartridges is having problem with it's print head. You need to replace it, but first you need to find which one. For best solution, we need a set of new cartridges so that there'd be no problem testing.
Let's begin like this;
Remove all the old cartridges, Turn off the printer, disconnect the all the cables including power cord and ethernet cable (if any), leave it Off for few minutes and again turn it on after connecting the power cord. Now install all the new cartridges and check if the error message is still there or not (Hope it's gone, but you need to find out the culprit from among the old ones so that you can use those that are functioning properly).
Now remove one for example yellow and install the old yellow and check the message, if it's ok, go on replacing with the corresponding old cartridges after removing the newly installed, and so and find out the cartridge which is the creating this problem. After that, you'll be able to use the other remaining old cartridges.
This might be a problem for you if you don't have a new set of cartridges, but this is the best way, you can also use old working cartridges [those with no more inks].
This will definitely fix. I would also suggest you to clean the contact points on the cartridges and on the printer properly using soft brush/cotton dipped in alcohol/acetone/spirit.
Good luck.
Thanks for using FixYa.
Posted on Jul 09, 2010
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
My printer Canon PIXMA iP6000D stopped printing and ERROR 5200 appeared.
Error 5200 is print head temperature rise,you need to change the print head.The part number is QY6-0050.If a have been useful please give me a vote :)
Mar 11, 2011 | Canon Pixma iP6000D InkJet Photo Printer
How do i fix my canon pixma ip6000d when i switch on error code 5100 appears
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Sep 25, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Canon pixma i6000d error code 5200
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Jun 28, 2009 | Canon Pixma iP6000D InkJet Photo Printer
5200 error, won't print
Here is a link where you can download the manual for your machine. Scroll down the page when you get there and you'll see the download links.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip6000d#BrochuresAndManuals
Hope this helps.
Dec 05, 2008 | Canon Pixma iP6000D InkJet Photo Printer
I560 error code 5200
Orange 10 5200 Replace the BJ Cartridge(Printhead)
Cartridge Overheat 8 x
7 times in orange/green 5200 Cause: The print head's temperature is abnormally high tnx and good day!!!!!
Apr 07, 2008 | Canon BubbleJet i560 InkJet Printer
580 people viewed this question
old marine
old marine
