Question about Garden
Snapper line trimer model S31Bc The pull string broke and we are trying to get the cluth off and need help at this point in the process
3 Suggested Answers
  • 760 Answers
SOURCE: I have a Homelite Model 26cs # UT32000 and the
Replace the string that's why it broke.
Posted on Jul 04, 2010
  • 532 Answers
SOURCE: snapper line trimmer the pull string
It is always a good idea to take pictures of each removal step to make reassembly easier.
Remove cover on the pull rope housing. Locate the flywheel which the pull cord wraps around. Remove screws or bolts that attach flywheel on the housing unit. Caution, be careful on recoil spring position. Locate hole on flywheel (side view) in which the original cord was feed through. Feed replacement into hole and tie a single knot. Reattach assembly.
These are the instrument you will used:
  • Screwdriver
  • Rag
  • Metal brush
  • Detergent
  • Gas
  • Fuel line
  • Fuel filter
Thanks for contacting Fixya.
T
r
Posted on Jul 09, 2010
I need a manuel for a Weed Eater String Trimer model W25SKF Speficically the primmer bulb to the carberator
Not sure what you are trying to do or if this will help, but it is a parts diagram of every part. The next is a You Tube video that shows how to take apart and many more weed eater videos to choose from.
http://m.tractorsupply.com/ProdContentPDFs/4041511_Man1.pdf h
How to Replace Trimmer Fuel Lines
May 05, 2015 | Garden
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Snapper line trimmer the pull string broke how do we change it
  • Screwdriver
  • Rag
  • Metal brush
  • Detergent
  • Gas
  • Fuel line
  • Fuel filter
T
r
Jul 09, 2010 | Garden
How to replace trimer line
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Oct 17, 2009 | Ryobi Garden
Describe string replacement on ryobi trimer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Jim
Jun 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
How to feed line into a black and decker trimer/edger model st6000 electric?
The ST6000 uses centrifugal force. Once you mount the new spool of string and thread it out of the feeder and into the housing below, plug it in, give it power and hold the line feed button down, feeding the line. Within seconds, the line will feed out through the head and you'll be in business.
Aug 08, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
