Question about OKI MICROLINE 320 Turbo Matrix Printer
At rear of printer where serial cable plugs in is loose and causes printer to stop randomly until i wiggle it, can this be repaired
  • 518 Answers
The serial has 2 small bolts which secure it to frame ,remove bolts ease out socket and see if wires have come off back of socket
Posted on Jul 09, 2010
A 2003 Pro Street Venom ran great for years. I replaced a lot. it gets hot and the rear jug stops firing I replaced plugs, wires, coil, ignition timing, checked connections. What the French toast?
Hi, Brian and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or electronic control module or CDI box.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Rear cylinder will not run
07 SuperGlide rear cylinder misfire HELP plz Harley Davidson Forums
No Spark on Rear Cylinder Help
http://motorcycles.voobay.com/usedmotorcycles/big-dog-k9-chopper-kits/160
Jun 24, 2016 | Motorcycles
I bought new ink cartridges and when i try to print something it gives me a error number 5100
Cause: Head too hot, exceeds the threshold, usually the color Catridge
Solution:
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 26, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
P08 in LED indicators for CAnon pixma mp 258... how to solve please
To solve your problem follow the instruction step by step...
Aug 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
I have Canon MP250 series I have a cde on led P 0 8
To solve your printer problem using the following directions..
Follow this instruction step by step.
Aug 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error 5200 or PO8?
Aug 12, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Printer shows alarm with p and 8 flashing
Aug 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon error p08 Problem
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 10, 2011 | Computers & Internet
99 dodge durango pcm and connectors heat up causing the vehicle to shut down until the pcm cools down then the car restarts I need a real fix tired of the car dying on me randomly. please help
it would be best if you took it to a dealer and left a mechanic take it home over night,that way he can have the Chrysler drb hooked up when the problem presents its self.
Jan 21, 2010 | 1999 Dodge Durango
OKI MICROLINE 320 Turbo Matrix Printer Logo
63 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
