Question about Canon PIXMA iP3000 InkJet Photo Printer
Printer Error when I switch on the printer green flashing light comes on. It continues to flash and begins to alternate between green and yellow colours. If I try to print a test page it gives an error that paper output tray is closed. Open paper output tray and resume. I don't know how to open the paper output tray. Why is the light not becoming stationary to indicate that printer is ready to print and how do I open the output tray?
There is button or clip backside of the printer.......u just press it and open the tray..........it is also possible that u don't attch ur usb wire to the cpu u just check it .........may be it will be good........
Posted on Apr 19, 2008
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
My Canon ip1600 wont print with new ink cartridge.
Visite the support tech and try to find a answer for you probelem:
Sep 09, 2009 | Canon PIXMA iP1600 Printer
Flashing green and yellow lights
You need to count the number of flashes to diagnose the error. Then go here and type error lights in the search box. You';; be able to follow the appropriate code to a solution.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | Canon iP100 Portable Printer
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer status screen is red and will not print Canon i560 Inkjet
You need to count the number of flashes, usually long green then a certain number of flashes, sometimes alternating red and green flashes. I need to know the number of flashes to tell you what the error is.
Jun 18, 2009 | Canon BubbleJet i560 InkJet Printer
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
Error 5100
Hello! Try this:
1. Unplug the power cord
2. While pressing the ON button, plug the power cord back in.
The power light should flash an orange/yellow color.
Continue pressing the ON button, and press the RESUME button 4 times. The light changes every time you press it.
3. Release both buttons, and restart the printer.
The printer should now stop blinking and operate as usual.
I hope this works for you. OMS
Apr 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
533 people viewed this question
old marine
old marine
