Problem in accessing hiden folder in win xp
When i try to activate show hidden folder and files it does not do anything
so i am unable to access my hidden files
  • sanmisu Sep 16, 2008
    accessing hiden foider in windows xp problem. plez......... help me give me a new solution .
    Scholar:
  • 75 Answers
If you are comfortable with using the registry, you can check this setting.
Start> Run > type: regedit and hit OK.
Go to this key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\
Advanced
Click on the Advanced folder in the left pane and in the right panel, look for the value name Hidden.
The value data should be 1 = show hidden, 2 = do not show
If you make a change, you have to reboot for it to take effect.
Posted on Apr 21, 2008
Iomega 1tb drive have files hidden
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ......
Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available. Hope this helps.
b>
Dec 10, 2012 | Iomega 1TB Prestige External USB 2.0 Hard...
I lost my outlook contacts
if there was a probledm with your login profile then you can retrive data from old profile from below location
C:\Documents and Settings\\Local Settings\Application Data\Microsoft\Outlook\Outlook.pst
is thae user name with you log in
Local settings folder might be hidden . you can access the hiden fodlers by checking show hidden files & folders fro windows explorer > Tools > folder Option > View tab > show hidden files and folders
Jun 03, 2011 | Computers & Internet
Virus cannot be deleted and hidden files that i cannot see
virus try another antivirus program to show hiden files control panel folder options select view then scroll to hidden files and folders tick show hidden files
hope this helps
Oct 08, 2010 | Computers & Internet
How to resolve the hiden windows
to unhide file extensions to see what you have in XP open my computer (or windows explorer) Tools/Folder Options/View ...change 'Do not show hidden files and folders' to 'Show hidden files and folders' uncheck 'Hide extensions for known file types' if you wish you can uncheck 'Hide protected operating system files'
to unhide file extensions to see what you have in Vista open my computer (or windows explorer) Organize/Folder And Search Options/View ...change 'Do not show hidden files and folders' to 'Show hidden files and folders' uncheck 'Hide extensions for known file types' if you wish you can uncheck 'Hide protected operating system files'
if this is what you mean
Nov 07, 2009 | Cars & Trucks
Can set up Windows XP to show hidden files/folders
go to controal panal in start then folder options then the view tab
You will have a option to view all hiden folders xp by default will have this turned off Thanx for using Fixya
Feb 17, 2009 | Microsoft Windows XP Professional
As I saved a folder(movies in it) in d drive and hide that but when I tried to see it again by going in folder option it did't show it again how to see that
You must change the setting for folders to show hidden files
That option is under controllpanel/folders
If you dont change that otion you'l never see the hiden files and folders, it's easy done, enter controllpanel, enter folders, under the second flap you will see an option "Handel hidden files and folder", chang that one from "hidde" to "show", press OK
Thats it!
Good luck
Dec 08, 2008 | Computers & Internet
Unable to activate show hidden folders
Based on your description, the OS is infected with a virus. The virus controls this so as to prevent you from seeing "unknown", "unfamiliar" files/folders and thus itself. Th easiest is to run your antivirus and an online scanner, clean/delete said viruses from your system and their support files. Some other indicators are, Task Manager will not show, "msconfig" will run but auto close as well as what you posted, Folder Options will not engage.
Additionally, you could try to:
  • download, install and run RRT.exe to force the registry into removing these restrictions;
  • download, install and run AdAware.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 01, 2008 | Microsoft Windows XP Professional for PC
Folder options in tool menu bar
go to >programs>my computer and open the C: drive. This is only to allow you to access the >tools menu and folder options. there you can scroll down and elect to see hidden files, extensions and system files. change the settings as needed and you shouls be able to see your hidden files.
Sep 22, 2008 | Microsoft Windows XP Professional With...
Accessing a folder.
This will sound off the wall, but we had something similar to this happen with my last laptop, where it was "access denied" in lots of areas, and we would have to find little backdoor ways to get into control panel and document files. The problem with our computer was that it had previously crashed, and we had rebooted and reinstalled the xp, but didn't have the registration number, so it would run ok, but to get into all those access denied things (which you eventually need to get into) we had to come up with our registration number.
Did it prompt you to enter the product key when you re-installed it?
Jun 27, 2008 | SmartDisk FireLite USBFLB120 120 GB USB...
Computer
for neerajay.. from what i understand, you cant find your files, so there must be some one that has deleted your data or you forgot where you left it
for both of you.. to find something, try using the search option from the start menu..
if you dont remember the name of the file but know the extension, type in *.doc to find word documents.. *.jpg to find pictures..
then, the results must show something that you can use to get your info back
Dec 17, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
