Question about Bosch 22 in. SKT5102 Free-Standing Dishwasher
No water filling the dishwasher.
The pump works and the dial completes it's cycle.
  • Bosch Expert
  • 414 Answers
The circulation pump is possibly leaking and has activated the flood safety, if you can get the unit near a sink and tip it you may find water coming out from the frame area. I would suggest if this is the case that you contact an expert such as BSH home appliances as these units can be quite tricky to work on if you don't have any experience.
Hope this helps.
Posted on Jul 09, 2010
  • 1 more comment
  • RascallyBear Aug 04, 2011
    Actually, there are several possibilities... It may also be one of the microswitches inside the pressure system.
    UNPLUG FROM MAINS POWER!
    The following directions are given (left and right) as though you are looking at the front of the machine.
    Your first task is to remove the white metal cover. It fits over the top of the machine and down both sides. It is easy to remove. You will need a 'Torx 15' screwdriver: the six-sided star head type, and an X head screwdriver.
    - on the sides, remove the small white screw covers, then take out the 4 Torx screws.
    - on the back, remove the X head screws from the white cover (NOT those on the silver base).
    - open the door, and locate the screws that are preventing the white cover from coming off. There are about six of these. You'll see which these are if you lift the sides of the cover and (gently) waggle it about.
    Once the cover is off, you need to look inside the workings on the right hand side. Move the machine so you have easy access. On the bottom right (looking into the workings) you'll see a white plastic moulding, approximately 5 inches (100mm) wide. In the top left of this moulding, you'll see a circular black plactic item, and to the right of this will be a smaller red circular item.
    Wires are connected to both the red and the white inserts. The wires are connected to microswitches and the black and the red inserts are floats. They are part of what's called the pressure system. They control when water is pumped into the dishwasher.
    (You'll also see a white circular expanded foam polystyrene disk under the white moulding. This lifts up if there's a water leak inside the casing. It also activates the microswitch attached to the Red insert.)
    OK, back to the microswitches.
    To remove and replace the switch on the black pressure chamber: pull off the multiplug. The chamber is held in place by two lugs. Using a small (electrician's size) screwdriver, GENTLY press on the casing next to the REAR locating lug, while gently pulling the chamber up-and-back. It should pop free. The microswitch is held in place by two claws visible next to the electrodes. Gently pull these appart (with your fingers) and the microswitch will come out.
    The other microswitch, the one over the red float, is accessed by removing the clear plastic cover (rock the cover while gently pulling upwards).
    If either of these microswitches has failed, the dishwasher won't fill.
    Examine, test and Replace the switches as required.
  • joegros Sep 06, 2011
    Hi, sorry to jump on this thread too but I have owned this dishwasher for about 3 years and it has been fine - until now!
    It does not seem to be filling up with enough water at the start of each program. It will fill up for 10 seconds or so and then the program will start fine, but I noticed that it sounded very noisy, as though it was emptying itself. If you open the door, there IS some water in the bottom, but clearly not enough for the machine to operate properly. I have temporarily solved the problem by adding an extra litre of water as soon as the pump starts (after the initial drain and fill). The machine then quietens down to it's usual (noisy!) self and runs perfectly. Well, until it gets to the next part of the cycle involving another fill, when I have to assist it again.
    Any ideas what the problem is? I'm guessing there is some kind of float to get the water level? Could that be sticking or something? Water inlet into the machine is same as it always has been, so don't think there is a problem there.
    Joe
  • jfrazer255 Feb 04, 2012
    Hi Joe did you fix your problem as we've got the EXACT same thing...is there a float somewhere in the Bosch SKT5102, can't see a problem with the inlet valve. We're on the verge of binning the machine and it's only just 3 years old....
4 Suggested Answers
  • 276 Answers
SOURCE: dishwasher cycles but does not clean the dishes
if your dishwasher is cleaning poorly, check these: Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
  • 1632 Answers
SOURCE: Dishwasher slowly fills up with water after wash cycle completed
Inside the bottom of the dishwasher under the lower rack to the side there is a float that regulates water level. jiggle it up and down a few times , it will be OK. Vitally
Posted on May 12, 2009
heatman101
  • 43501 Answers
SOURCE: My G.E. dishwasher model GSD500-01AW
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 12, 2011
Dishwasher does not complete cycle
Does it have standing water after cycle? If so you can turn the knob until you hear the water kick into the sink. let it drain this way completely and stop the dishwasher before it starts to add more water. turn the dial or switch to its off location and the let the dishwasher cycle completely to ensure issue is solved. Your dish washer is "short cycling". This usually works 9 of 10 times
Oct 28, 2013 | Dishwashers
CI am having a problem getting our Miele G575 dishwasher to run through a wash cycle. It definitely has power, the water is on and there is no water in the bottom of the dishwasher. When you turn the...
You said it does not progress...meaning the dial does not eventually move? it may be waiting on a water level sensor to be tripped. The dishwasher is just not filling. The water valve solenoid may be stuck or defective. or a wire may have come off the valve solenoid.
Mar 08, 2011 | Dishwashers
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
My neff dishwasher will not fill will water and will not complete program - cleaned and checked filters to the best of my knowledge - can you help?
i if it doesnt fill with water check it is actually draining is there water in the tub etc?if it cant drain it wont fill or complete the cycles,this is usually a blockage in the pump the handbook tells you how to deal with this problem.
Jul 29, 2009 | Neff 24 in. S5555X0GB Built-in Dishwasher
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Dishwasher not drying properly; water in the cups/plates
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Dec 06, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a GE roll around dishwasher, Model GSC3200Z03BL. It worked one night, did not work the next. After hooking intake/discharge hose to faucet and turning to start, no water is pumped in. Only a...
First off.. the pump does not let water in.. it takes water from your sink faucette via the hose and allows it to enter the DW via an inlet electrically operated valve. If that valve is not commanded by the control system to open, then no water will enter the DW and a wash cycle will not start. Please find the informaton shown below that decribes some reasons why your DW may not be filling with water. You should go thru this series of checks to make sure you've set up the DW correctly aqnd it is not in mid cycle.If by chance you are setting it up correctly and are not in mid cycle then you may have a hardware problem with the system. I would be happy to assist you if it comes to that but I am hoping that the information below will get you started,...
Copied directly from the GE website for your refererence..
Dishwasher - No Water Fill
Often the cause of a dishwasher not filling at the start of its cycle is not electrical or mechanical. Often times you may be starting your dishwasher model incorrectly which results in the machine skipping its first water fill period.
There are presently three different types of starting procedures being used:
  1. Pushbutton type. This system is found on all POTSCRUBBER models.
  2. "Turn-to-start" timer type. After latching the dishwasher door, you turn the timer dial until you hear a click. By advancing the timer dial beyond that point, its possible that the first water fill would be skipped. The first fill is necessary for automatic pre-rinsing of the dishes.
    View a short video about turn-to-start timers:
    Play Video
  3. The most common type is a "push-to-start" timer dial. All that is required to initiate the cycle is to push in on the timer dial. It is NOT necessary to turn the dial.
If you are unsure as to the starting procedure used by your model please consult the Owner's Manual. Download a free copy of the Owner's Manual and/or Installation Instructions.
Here is a link to the website too.. http://www.geappliances.com/search/fast/infobase/10001005.htm
Hope this gets you going..
Sep 02, 2008 | GE Dishwashers
It fills, but doesn't kick in to spray/wash
Main pump not running?...then it will either be the program controller or the main pump itself.....I would guess the pump first.
Jul 17, 2007 | Kenmore 15522 Built-in Dishwasher
Bosch 22 in. SKT5102 Free-Standing Dishwasher Logo
268 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
