Question about HP Photosmart 375 InkJet Printer
When I insert a SDHC memory card in printer,I get card access error message.How can I solve this problem?
    Brigadier General:
  • 3,006 Answers
Your printer was designed to use SD cards with a maximum 2GB capacity. It was not designed to be compatible with SDHC cards and cannot read them.
SDHC cards are a later development and will fit into the same slots, but are technically different. As the difference is due to hardware incompatibility, there is no way to update your printer to accept the later standard.
Posted on Oct 06, 2010
Printer says, is not compatible
Posted on Mar 11, 2011
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
I have a new sdhc 8gb card but get error message when inserting into my HP1610 all-in-one printer . Can you help
... and the text of that error message is __________________________________________
> new
Take it back, and get a replacement, under WARRANTY.
Jun 04, 2011 | SanDisk 4GB microSD High Capacity Memory...
I have a gateway DC-T50 digital camera. I put in a new 2GB SD memory card, formated the card, but when I go to use the camera I get error msg i inserted a new 2GB SD memory card, I formatted it, but when I...
Is it an SDHC card? SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 20, 2010 | Gateway Cameras
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Memory card reading " card access error" when printing
is this a SDHC card? if so do u have a SDHC card reader?
Sep 17, 2009 | SanDisk Memory Media
Cannot get pictures off of SDHC Card 4GB
Could be it only supports SD cards up to 2gb but not SDHC.
Jun 16, 2009 | SanDisk 4GB microSD High Capacity Memory...
Sdhc card says error in my printer
SDHC cards work for most cameras but many printers cannot run SDHC cards I have had the same problem and getting a usb cord for my camera worked just fine
Jun 02, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Photosmart 380
when XD card is inserted printer says "card error"
Apr 23, 2008 | Office Equipment & Supplies
HP Photosmart 375 InkJet Printer Logo
861 people viewed this question
Seeker5211
Seeker5211
