Question about Jenn-Air Kitchen Ranges
Jenn-air range - model #JGS9900CDS my oven control panel functions are not all working - i can't turn on the bake or broil. the timer works and some functions in the setup and favorites work, but not all.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Whirlpool oven that does not broil
Nabril, looks like you have a thermal fuse in the broil circuit. Take your meter and on the control board go to connector P2-2, should be a blue wire. Pull the connector off and see if you have continuity from the blue wire to the red wire on the terminal block (where the cord connects) power off, wires off. If you don't have continuity, it's probably that fuse. If you do, the only other thing I would think it could be would be the relay itself. The schematic does not show the placement of this fuse. It could be on the back panel or under the main top. Check out the pic. Part number..3196548 Catriver..post back.
Posted on Apr 21, 2007
SOURCE: Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Posted on Aug 12, 2009
  • 106 Answers
SOURCE: range control panel does not work , cant set
You may have locked the touch pannel by acident. The child safty lock button looks like a pad lock or may say lock. hold it down for 4 sec to unlock.
Posted on Nov 11, 2009
SOURCE: GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Posted on Jul 15, 2010
Jenn air sve47600w
with wiring diagram check to see if any power to circuit board. check any limit switches in line in oven circuit. then check the following.sounds like a circuit board problem. turn power off for a minute then try again. also with power off unplug all connections to board and plug back in. if still problem replace electronic oven control board.
Nov 16, 2013 | Ovens
Funny - didn't ask about a slide in electric kitchen range - was asking about my Jenn Air Stove. You deal with them, correct? Have a Jenn Air WW2780B that I can't seem to get working. It started...
I had a customer with the same problem last month and I believe it was on the same model as yours. Let me look in my database and I will get right back to you.
Warmest regards,Richard
Nov 01, 2011 | Jenn-Air SVE47100 Slide-In Electric...
After baking and trying to set time bake a week ago, the range won't turn on at all. Nothing happens when we press bake, broil, convect bake, etc. The clock, lights, fan, timer and cook top still work.
the oven controller in the main service/selection panel has either a bad solder joint on the circuits or the start realy for the oven on the same circuit board is bad and you have to replace the whole panel you cannot just buy the relay
Jan 20, 2010 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Jenn-Air range SVE47600W control panel is partially non-functional. Bake temperature control, off, oven light work. Clock does not display, oven clean and broil do not function. It may need a new panel...
We have this part in stock and can send it out to you first thing Monday morning, if you like. We will include installation instructions for you. You can call us from 7AM until 9PM CST Monday through Saturday. We look forward to working with you!!
Oct 15, 2009 | Ovens
Aug 11, 2009 | Kitchen Ranges
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
Thermador 30" Dual-Fuel Range 0FF error
I am quoting above because I really need help. "When I push any of the function buttons on the oven console (Timer, Bake, Broil, Clock) the display shows 0FF in red next to the clock. The oven will not turn on and the timer will not work. I can not find any troubleshooting information on this problem. The oven is a model RDDS30V. Any help would be greatly appreciated!"
Apr 17, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Kitchen Ranges Logo
461 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
