Question about Dishwashers
Kitchen aid kudk031tblo diswasher has a noise and
Kitchen aid kudk031tblo diswasher has a noise and the water does not stay in machine
4 Suggested Answers
SOURCE: Kitchen Aid diswasher controls don't work
The Button is part of a switch control (all the buttons are individual switches) - take the switch block out of the door and test the button (switch)for circuit continuity, if it is OK, then the timer control may be the problem. My machine had progressive failures through the various cycles until most do not work and it wa the timer that was failing bit by bit.
Posted on Oct 03, 2007
SOURCE: some water stays in dishwasher (beau mark portable dishwasher
The manual says that's normal: "A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated."
Posted on Dec 19, 2008
  • 22 Answers
SOURCE: I have Kitchen Aid dishwasher
99% of the time it is the thermal fuse on the control board. I have seen this about 12 times now. In one of the cases i found the circuit it was wired to, was way overloaded and was browning out power to the dishwasher.
Posted on Mar 31, 2009
Defy dishmaid DW12
You have a major short to ground which is tripping the breaker. Get an electrician to check the machine, it may be as simple as you have trapped the cable. Don\'t mess with water and electrics. Electricity is the silent killer.
Aug 21, 2014 | KitchenAid Kitchen Aid Diswasher Part...
My dishwasher smells like dog
dishwasher magic. can be found at walmart for 5 bucks. works great to clean and condition the inside of the machine and the pump and motor. recommend every 3 months
Oct 27, 2013 | KitchenAid Kitchen Aid Diswasher Part...
I have a new kitchen aide dishwasher. Does any of the insulation padding come off before installation
No. It is supposed to remain on the dishwasher. It helps cushion the machine noise from vibrating through your counter.
May 26, 2012 | KitchenAid Kitchen Aid - KUDC10FXSS...
Kitchen Aid Diswasher does not advance to the wash cycle
the hum worries me, from your discription sounds like a wash motor may be bad, or something is blocking the pump from turning, unless your are really handy, i suggest you call for service.
Sears offers what they call and SSA on their 800 # if you buy the SSA it will include the repair you need and a 1 yr warranty. good luck
Jan 07, 2012 | KitchenAid Dishwashers
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Water not flowing from Kitchen Aid Refrigerator. I've switched the filter and it has not resolved the problem. the unit is one year old, was working properly. 2 days ago, water leaked from spout and that...
water maybe frozen somewhere in the system. may need to disconnect water connections at various points and retry to narrow down where freeze up is at.
Jan 06, 2010 | KitchenAid Refrigerators
Not getting any water into the kitchen aid dishwasher
it could be the water inlet valve. that is definitely a DIY job. but first i would check out the float inside the machine. if it is stuck in the up position, no water will enter the machine. it will assume that it is already full of water. look for a small hat or cone on the bottom. make sure that it slides freely up and down. if it was stuck up, you will have just freed it and solved your problem. good luck
Nov 04, 2009 | KitchenAid Dishwashers
Seems that there is not enough water pressure to reach top rack
I cleaned the food out of the filter/ chopper. I found a web site that showed me how to properly remove the parts to access where the food was cloging the intake. This is a necessary maintenance that will be required for every Kitchen aid diswasher and is not documented in the manuals. It saved me a lot of money doing myself.
Jun 21, 2009 | Whirlpool 24 in. ADP5962 Free-standing...
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Kitchen Aid Superba Dishwasher
check the holes in the spray arms to see if they are plugged also brand and model number will help
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
Owen Barnes
