Could the lamp be burnt out? If it is, the lamp is not replaceable in this unit.
I looked up the error on the hp.com site and could not find much about it except that there is mercury in the lamp and it works off of a CCD.
Only the following parts are available from hp.com:
HP Scanjet Scanners - HP Scanjet 3970 Digital Flatbed Scanner User Replaceable Parts and Accessories (EMEA)
Introduction
This document provides information on obtaining user replaceable parts and accessories for the HP Scanjet 3970 Digital Flatbed Scanner in Europe, Middle East and Africa.
Parts
Interface cable
Part Number
Part Description
C8507-47300
Universal serial bus (USB) interface cable with ferrite - Type 'A' connector to type 'B' connector - 1.7m (5.7 ft) long
C9930-80003
Universal serial bus (USB) interface cable (Black) - Type 'A' connector to type 'B' connector - 1.83m (6.0ft) long
Power cord
Part Number
Part Description
8121-0731
Power cord (Black) - 18 AWG, three conductor, 1.9m (75in) long - Has straight (F) C13 receptacle (For 220V in Europe)
8120-6260
Power cord (Black) - 18 AWG, 1.0m (3.3ft) long - Has straight (F) receptacle - (For Saudi Arabia)
8120-6262
Power cord (Black) - 18 AWG 3-wire, 1.0m (3.3ft) - Has straight (F) receptacle - 240V Europe (except Denmark, Ireland and Switzerland)
8120-8881
Power cord (Black) - 17 AWG 3-wire, 1.0m (3.3ft) long - Has straight (F) receptacle (For 220V in Denmark)
8120-8882
Power cord (Black) - 17 AWG, 3-wire, 1.0m (3.3ft) long - Has straight (F) C13 receptacle (for 240VAC in the UK and Ireland)
8121-1003
Power cord (Black) - 17 AWG, 1.0m (3.3ft) long - Has straight (F) receptacle (For 220V in Israel)
8120-8885
Power cord (Black) - 17 AWG 3-wire, 1.0m (3.3ft) long - Has straight (F) receptacle (For 220V in Switzerland)
8120-8886
Power cord (Black) - 17 AWG 3-wire, 1.0m (3.3ft) long - Has straight (F) receptacle (for 240V in South Africa)
Power module
Part Number
Part Description
L1970-80003
AC power module (brick type) - 100-240V, 50/60Hz - EC Rohs/Energy Star, 15W - Requires a detachable power cord.
TMA (Transparent Materials Adapter)
Part Number
Part Description
Q3194-69001
Cover (document lid) - Includes TMA
Q3852-69002
Template for photograph negatives - Used with the TMA
Accessories
Hub
Part Number
Part Description
Q2707-61600
USB 1.0 hub kit - Includes hub, power supply module, and USB interface cable with Type 'A' connector to type 'B' connector, 1.5m (5.0ft) long - 100-240VAC (UK)
Q2707-61601
USB 1.0 hub kit - Includes hub, power supply module, and USB interface cable with Type 'A' connector to type 'B' connector, 1.5m (5.0ft) long - 100-240VAC (Europe)
To buy any of these user replaceable parts and accessories, click on the how to buy link at the top of the page.
function submitTo(f) {
var msg="";
var message;
var helpValue="";
var easyValue="";
var i=0;
var index=0;
var flag=1;
var f = document.feedbackForm
var radio1 = false;
for (i=0; i") != -1 ) {
m = m.replace(">", "-");
if (m.indexOf("") ==-1) {
flag2=false;
f.comments.value=m;
// JAGaf87381- Document Feedback doesnt accept Greek input
// f.comments.value = escape(f.comments.value);
f.submit();
}else{
I guess you know that this is a Mechanical problem, it simply means the lamp which scans the document is not working properly. It's the bar like unit emitting very bright light which moves to and fro just below the scanner's glass.
There are three basic possibilities with this error.
First, open it apart the check the scanner and remove the Lamp, now reconnect it after cleaning the connectors, contact points and the interfaces with cotton dipped in alcohol or spirit or acetone. Place it properly on it's position and power on the printer, check whether the error is still displaying or not. No positive outcome? Then switch off the machine and disconnect it, check the continuity of the flex cable, if it's alright and you see no continuity problem, then the problem is with the lamp or with the board or connectors, during this situation, you'll need another spare to check the issues so that you can find out the problem.
If there's continuity problem and you find it fault, replacing the cable will fix the problem.
On the other hand for connectors, you need to do it very carefully and look every connector points with great effort if you can see any bent or twisted among them, if you are sure that there's nothing to do with it, the the problem must be from the Board which is not as easy as we think could be repaired. You can replace it, while there a problem, we can't find the spare, and so it will be difficult but you could possibly get the one from a Repairing shop or Servicing Center.
*Warning*: If you know how to do all these things, just go ahead or else, please take it to a Service Center or call a Tech and get it repaired. Without proper knowledge, you may damage it if in case it could be easily fixable.
I wish you Good Luck.
Thanks for using FixYa.
I need to find a web site that provides instructions on disassembling the Hp Scanjet so I may replace the lamp and provides basic professional repair details . I am an engineer and am able to do basic component replacement and contact cleaning.
