Question about ViewSonic VG2021m LCD Monitor
After pressing the power on button it starts to turn on but then makes a hissing sound and goes into standby mode. It takes several attempts before the screen wont make the hissing sound and finally stays on.
  • 1,684 Answers
You have a monitor with a failing power supply. The Viewsonic VG2021M monitor uses the DAC-12M033 power supply board. After several years of use the capacitors in the power supply start failing and not keeping a charge. The capacitors are on the output side of the power supply and help filter and stabilize the voltages. When they fail the power does not settle when you turn it on so you have to do the on/off/on/off to get it to start. If you can solder then you should be able to repair your monitor. Check out the article on our site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ it is for the Westinghouse LCM-20V5 but they both use the same board so the repair information is the same. If you don't want to do the repair yourself we do offer a repair service for this unit, it runs $32 plus shipping. You can get more information on this service here:
http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Posted on Oct 27, 2010
My PS3 has no menu. No sound or video
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we...
try video reset
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Technics amp crackle and ''hiss'' noise
in my car when I press the accelerator there is hissing sound,did check the air filter by disconnecting the plumbing but still the sound is present any idea what could be causing this sound.
May 25, 2009 | Audio Players & Recorders
Lexicon RV-8 wakupe failure
Did you try this....
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
POWER MANAGEMENT ON, OFF
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
position.
2. Attempt to power on the RV-8 with the front-panel Standby
button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
Apr 05, 2009 | Lexicon RV-8 V2.0 Amplifier
STUCK ON STANDBY MODE
Ok, I want this off my screen. If it is stuck in standby mode as you say, press and hold the power button until the computer goes "dead." Then turn it back on. If this doesn't work, unplug it and take the battery out for a while.
Nov 22, 2008 | IBM ThinkPad T22 2647 Notebook
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Standby problem
When a alptop goes on to standby its quite common to require you to press the power button.Just turn off and power saving and standby problems you have by going into power management in control panel.
Mar 28, 2007 | HP Compaq Presario V2000 Notebook
ViewSonic VG2021m LCD Monitor Logo
505 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
