Question about GE GSL25JFPBS Side by Side Refrigerator
Cannot get water out of front despenser but can get Ice
  • 3 Answers
Found that when I used the crushed ice option, the lines would freeze up. Cubes were ok. Take everything out, including the ice, and turn it off for about 12 hours. Then check to see if it works again. If not, wait a little longer to let it fully defrost. If it still does not work after 24 hours, then you might need service.
Posted on Jul 13, 2010
  • boopsipookum Jul 13, 2010
    I found that when I used the crushed ice option, the lines would freeze
    off for about 12
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
Water and ice despenser doesn't work
you have a dual water valve one side for ice and other for water ( foutain ) but both never fail at same time so look at the pc board ( touch contorl on front of door this is prob the problem . ck for loose connections to board .before replacing .it .. mm
Aug 10, 2010 | Maytag MSD2756G Side by Side Refrigerator
It despense water, but does not make ice
Either the water valve is bad or the icemaker is bad, assuming it is turned on.
Check the valve with the wires off with an ohmmeter.
If it shows continuity, the icemaker is bad.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
Water just keeps pouring out of the top of the ice despenser
I would say your water valve in the freezer is locked in the open postion or has broken.
Jun 07, 2009 | GE GSH22SGRSS Side by Side Refrigerator
Ice maker will not despense when full of ice
Hello , that is exactly what is happening this is caused by 1 of 2 things.
1- the module/control on the front of your ice maker is sticking during its cycle and over timing the fill stage.
2-your inlet valve located in lower rear at water line connection is not sealing causing water to seep through line to ice tray and overfill.
Both are common issues and the most cost efficient way to repair this is to order the ice maker kit that contains both the ice maker and the valve so you can guarantee the fix.
You can purchase on line with your model number for around $100 Calling a service company will cost at least $150 changing only one of these parts or about $200+ for both.
If you have any questions please ask and let me know how it goes.
Phil
Jan 02, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Ice Maker
ice Freezs in storage tray
Apr 19, 2008 | Maytag MSD2732GR Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
102 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
