Question about Sammons Preston Treadmills - Gaitkeeper 1800L Treadmill
Can you tell me how to reset my ultrafit model dk2510 treadmill i was on it and it just stopped
Proform tredmill starts runs 10 sec and beeps twice and stops
I would suggest unplugging the unit from the wall and waiting 30 second and plugging it back in. Then go to where the AC cord enters the machine and look for a reset button or switch. Put it in the reset position and see if this solves the problem. Depending on model the reset may be on the bottom of console.
Dec 15, 2013 | Proform 520 Trainer Folding Treadmill...
Image 15 treadmill troubleshooting
Reset the treadmills and fix it. God bless you
Instructions 1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 13, 2013 | Cadence Exercise & Fitness
Technogym I am getting message "Your Technogym is blocked" Could you tell me what I need to do to remove this?
follow this steps and fix it. God bless you
    • 3
    • 4
    • 2
Oct 17, 2013 | Exercise & Fitness
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
V-fit treadmill dk2510 starts but stops as soon as speed goes past 1.5 mph
1) Run the software calibration for easy diagnose, troubleshooting, and fix it.
2) You must adjut the speed sensor, clean and tight the wire connector.
God bless you.
Jun 12, 2012 | Exercise & Fitness
My ultrafit treadmill won't run-the control panel
2_15_2012_4_45_37_pm.gifAdjust the reed switch as indicated by the diagram by 1/8- 1/4". Run the calibration software instruction under the Hood motor or see your user manual.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Exercise & Fitness
Z8 is showing L5 cant seam to fix this
Dear Sir:
I will try to help you, please use the steps with patience and carefully: You must need some basics tools; Included Dvom (Digital Voltemeter).
Instructions Things You'll Need for to Reset Code:
  • treadmill (all models applicable)
1.
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill
Oct 19, 2011 | Spirit Fitness Z8 Treadmill
I have an EPIC treadmill that is about 3 years old and I use it regularly. (not sure the model number at the moment, as I cannot find the booklet) The other night about 2 minutes into my workout, it...
You will need the model number in order to order the correct parts. Under the front cover there is a tech sheet. It will tell you the model number. The model numbers are usually on the frame, and can be found once the treadmill is folded up. Yours will be something like EPCL******.
It sounds like you may need a motor controller PCB. The motor might be defective, but they generally don't just stop like yours has...
The model number tag also has a phone number to call for service. They can send someone out to look at it if you require a technician..
1-888-922-4222
Dec 14, 2010 | Epic Exercise & Fitness
Treadmill is plugged, lights are on but does not work
The standard calibration procedure to calibrate an Icon treadmill is done by holding down the speed up and stop keys while inserting the safety key or putting the key in place (if magnetic). If your keypad is not responding, because your treadmill keypad has failed or the console computer has failed. In these cases, the keypad can be replaced in limited instances or the console has to be replaced.
Now if you are able to get in calibration mode then Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, This means that it passes the EPROM test. If it shows ff or 2f your upper console will need to be replace.
Next step if eprom passes: Press either incline key and the incline will calibrate automatically.
DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). if you get the the number to 85 and the belt does not move , on the lower board you will see a like flicker that would be the speed control this tells you that the upper console and terminal cable is good ,but lower board defective.
May 20, 2010 | Epic View 550 Treadmill
Walking belt for vitamaster 700
ultrafitness equipment.com we got belts cheep 4 every make and model
Jan 27, 2010 | Exercise & Fitness
Sammons Preston Treadmills -  Gaitkeeper 1800L Treadmill Logo
118 people viewed this question
Top Sammons Preston Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Sammons Preston Exercise and Fitnes Expert? Answer questions, earn points and help others
