Question about Brother LS-1217 Mechanical Sewing Machine
My needle thread tensioncontrol knob came off .How
My needle thread tension control knob came off .How can I fix this ?
SOURCE: sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Posted on Oct 29, 2007
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
SOURCE: The upper thread keeps breaking, even though I
Have you change your needle? I've the same problem adjusted the tension but when I changed the needle, it worked fine. If that doesn't work, you might want to take it into a sewing service shop and have them take a look at it. They should be able to tell right then what the problem is. If it is a severe problem and you don't have a spare machine, you might want to ask if they will give you a loaner. Usually they will give you a machine to use until your machine is fixed. Hope this helps!
Posted on Apr 12, 2009
Australian S
  • 46 Answers
SOURCE: Replace the needle thread tension dial
If the entire assembly has fallen out you will find if you remove the top left hand cover that there is a small screw in the casting where the tension assembly goes, replace the tension body to the correct position and tighten the little screw.
Posted on Jul 02, 2009
mohammed387
  • 1952 Answers
SOURCE: my needle thread keeps bunching and llooping on
If you getting loops on the bottom of your material, you need to re-thread the top of your machine. I say this because it is very rare when you will have to adjust the bobbin tension. But if you must, looking straight down at the bobbin as a clock- at 6:00 is the bobbin tension adjustment- lefty lucy, righty tighty. Hope this helps.
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correct
There is no standard tension for any machine to be set at. They start at four when they are brand new, however, after years and years the springs become compressed. You could start at four and then play around with it from there. If you are getting loops underneath the material, you are threading the machine incorrectly.
Posted on Jul 15, 2009
The tension knob will not turn below four. The thread keeps breaking.
check that the thread is between the plates and not behind them
thread breaking can be from wrong size needle eye, poor quality thread , old thread and needle/ eye timing
Dec 11, 2015 | Singer Merritt 8734
I have an Eden Rose 250M, for several months no. Suddenly the thread tension is not working properly. I've tried all suggestions in the manul but still the needle thread is very loose. The b
The tension control has a screw on the inside wall of the sewing machine. It probably came loose and will not allow the tension to pull taught. If you take the top off you can look down to where the tension knob is coming from. There is a screw that you can tighten while you push forward on the tension knob while set to zero. Keep the presser foot up.
Feb 01, 2015 | Husqvarna Sewing Machines
My top thread frays and then breaks while I am quilting with my 1600p dbx.
change to a new needle
check to make sure thread has no knots or even change the thread spool
check the top thread tension it sound like it's to tight
check the needle plate for burrs
check around the tension knob for loose pieces of thread or lint
use a can of air that you'd use on a computer keyboard on the tension knob & if you don't have the can of air use unwaxed dental floss but make sure to write down the setting it was on before cleaning.
& also under the needle plate area in case there is loose threads or lint & also the bobbin area
Aug 11, 2011 | Janome 1600P-DB Mechanical Sewing Machine
Singer 2517c -I need Threading instructions please. Also the top thread is loose -how do I fix that
Lift the needle to the highest point by turning the handwheel. Lift the pressure foot to release the tension on the system. Place the spool on the spool pin and put the spool cap on to hold the spool firmly.
Next bring the thread to the thread guide and snap it into the guide. Then slide the thread under the guide and through the slot (use one hand). Next lead the thread down on the right of the tension knob and up on the left. This puts the thread in the tension discs. Next slip the thread into the take up lever. (Bring the thread to the top of the lever and back towards the machine. Then slide the thread into the slot on the take up lever and then back towards you.
Next lead the thread through the next pair of guides. One is on the machine below the take up lever; the other is attached to the needle holder.
Finally thread the needles from front to back.
First check if there is a slight drag on the upper thread when you pull it through the machine (pulling it under the foot of the machine). Move the tension knob to the right to increase the tension. When you stitch a test piece, your top thread is visible on the bottom of your sewing thread, rotate the tension knob to the right by half a turn (get the dot closer to a higher number).
If there is no change in the tension as you turn the knob, take the machine for service. The springs in the tension system may need to be replaced.
The manual is available from Singer here: http://www.singerco.com/accessories/manuals.html . Enter only the 2517 model (leave off the c). A pdf is available for free; there is also an option to order a hard copy. A picture of the threading route is on page 28 of the pdf (page 26 as the manual is numbered).
I hope this helps.
May 12, 2011 | Singer 2517 Mechanical Sewing Machine
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
Tension is suddenly too loose. I have adjusted the top knob to no avail. it continues to be an incorrect stitch.
Raise the presser foot lever (this opens the tension control). Pull about 6" of thread through the needle.
Lower the presser foot and this closes the tension control to your selected setting.
Why? When the tension control is open when threading, the thread seats into the the control and can be properly "tensioned" for a proper stitch.
If this does not resolve the problem, then the machine needs to go into the shop for service. It could be the timing or the tension control needs to be repaired or replaced.
Service begins around $70 plus parts.
Trying to fix this yourself could be more costly.
Mar 27, 2010 | Sewing Machines
Unable to get bobbin to pick up thread from needle.
Check the thread coming out from the bobbins maybe on reverse side,also check the bobbins tension adjust it there is a small adjusting screw.Check also the needle alignment lastly check the upper tension from the tension regulator knob,tension adjustment is depend on the fabrics that you sew.
Mar 06, 2009 | Necchi 3102 Mechanical Sewing Machine
Mylock 134d janome
make sure the needle is pushed in properly.
Jun 24, 2008 | Janome MyLock 634D Mechanical Sewing...
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Brother LS-1217 Mechanical Sewing Machine Logo
63 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
