Question about Nintendo GameCube Console
My GameCube's analog stick has a problem. When I go forward and release it, it turns around and goes another direction. What can I do? It's a GameStop brand controller. I have tried disassembling it and thoroughly cleaning out the analog stick's mechanism (and it was dirty). When I put it back together and plugged it in, it seemed to have fixed the problem...but a few minutes later the problem returned. What is causing this and can I fix it?
SOURCE: Gamecube controller [suddenly] not working with Wii
logic 3 controllers are not good, return the logic 3 controller to the store and buy a NINTENDO wavebird instead, i bought mine used and it is perfectly fine. you might have the controller plugged into port (....[4]) instead of port ( . [1]) so try that or buy a wavebird instead ( if you ask me , buy the wavebird). I think my sister's friend's brother had the same problem. But he gave up on it. Probably faulty. Third party gamecube and wii accessories (excluding nyko) are bad or do not last very long.
Posted on Jan 25, 2008
SOURCE: PS3 Controller Jams
Have you found a solution to this problem? I have the same issue for the right stick. I played the SKATE demo a couple of times and that exaxt thing happened to me. Help please.
Posted on Aug 23, 2008
  • 26 Answers
SOURCE: unable to read disc error
If Wii gives Unable to read Disc Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Feb 25, 2009
  • 8 Answers
SOURCE: NintendoDS- touch screen fault
thats a shame lets get something done about it warrenty info
you can use this to check if you have a valid warrenty warrenty lookup
i hope this helps good luck!
Posted on May 28, 2009
lostinfamily
  • 149 Answers
SOURCE: Problem with my Wii Gamecube contoller's analog stick
It sounds to me that the solder joints are bad. If you are good at soldering I would take the controller apart and look at where the joystick is and on the back side apply the soldering iron and allow the solder to adheir to the joystick post. This should fix your problem. Please rate this as a FIXYA if this corrects your problem.
Posted on Jun 10, 2009
Analog problem
Do you mean it the analog stick turns left or it turns left in-game?
Jan 30, 2014 | Sony Dual Shock 3 Controller for...
Left analog stick My Xbox left analog stick does
Analog stick might be bad and may need replaced. If you don't feel comfortable tearing it apart, you may want to look into a new / used one.
Oct 12, 2013 | Microsoft Xbox 360 Controller
Ps3 controller manual
You plug in the usb cable to charge the controller and connect it to the ps3 for the first time. You use the left analog stick to move around the dashboard when the ps3 is turned on and the 'X' button to change settings, go to the online browser, playstation store, or start a game. You can back out by pressing 'O' or holding the 'PS' button, which allows you to change a controller number (say controller #1 to #2 with two controllers), turn off the system or turn off the controller. Press (not hold) the controller to look around the dashboard while in a game and select say "Quit Game', or go into settings and change something around to your liking. Every game also comes with the controls and for what the buttons are. (Stick on left is the, "Left Analog Stick," right is "Right Analog Stick," from right to left starting at the green triangle shaped button is the, "Triangle," "Circle," "X," and "Square," buttons. The four buttons on the left going in all directions is the D-pad, and the triggers on the back going from the top left to bottom left and top right to bottom right are, "L1," "L2," "R1," "R2").
Feb 05, 2013 | Sony PS3 DualShock3 Wireless Controller...
The left analog stick stuck to the left
You need to recalibrate the the analog sticks. To do this you need to take out one of the two batteries then press and hold L1 and L2 at the same time. While holding L1 and L2 insert the battery you took out earlier. Now you can release the L1 & L2 and your analog sticks should be centered. Do not touch or move the analog sticks during this process. If this fails to recalibrate then repeat the procedure again.
May 15, 2010 | Logitech Cordless Action Controller for...
I cant find a button on my nitendo controller
your z button is usually a trigger button but if this doesnt help try looking at the first few pages of a games manual they always show a pic of your paddle and what buttons
HOPE THIS HELPS HAPPY 24TH
Jul 19, 2009 | Nintendo The Legend of Zelda: The Twilight...
How do I kick off in ncaa football 07 for xbox
You use the left analog stick to position the kick. When you are ready, pull back on the right analog stick and when the gauge fills up, press forward on the right analog stick. The key to a good kick is to position the right analog stick in the same direction of the kick. (As if you were kicking in the direction your turned with the left analog stick.)
Good luck and happy gaming!
Mar 22, 2009 | EA Sports NCAA Football 07 for Xbox
My PS2 controller's L3 analog stick is broken.
I think I know exactly why. I bet you have a Pelican controller huh? Those analogs wear out after a while. You need to go buy another one, lol, sorry. They are only 10 bucks. Please rate!
Jan 01, 2009 | Sony PS2 Dual Shock 2 Controller...
PS3 Controller Jams
Apr 25, 2008 | Sony Playstation 3 (PS3) Console
Analog stick and d pad on psp
First of all DONT PUT YOUR UNIT ON THE FRIG. you have a contact problem. You need to replace the rubber contact on your D-Pad and Stick. Or just clean it inside if you can open it.
Aug 06, 2007 | Sony PlayStation Portable (PSP) Console
Nintendo GameCube Console Logo
48 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
