Question about Kenmore 24032\24036 Top Load Washer
Cycle sticks on each cyle and I have to manualy move it to the next cycle. Will stay on each cycle for hours if I don't watch it. Is it the timer?
    President:
  • 1,937 Answers
Most likely it is.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following for how to release the console to gain access to the timer
:http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Then see the following Whirlpool / Kenmore Service Manual for top load, direct drive washers with troubleshooting and testing procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Jul 10, 2010
The timer control switch sticks
You have a faulty motor on the timer and it will need to be replaced. Here is the part to order.
Dec 07, 2012 | GE WSXH208A Front Load Washer
Fridge stops to defrost and wont start again unless i do it manualy by turning the timer with a screw driver.
A mechanical timer defrost cycle is approximately 23 minutes, and it occurs at intervals of between 6 and 12 hours depending on the timer. If it does not come out of the defrost cycle on it's own, your timer can be bad. Be sure the heater actually comes on while in defrost. Also be sure the evaporator (freezer) fan is on when in the cooling cycle. If both of these occur. Replace the timer. It's important that the timer be replaced with an identicle timer.....6 hour for 6 hour, and that the 4 numbers by the electrical contacts be in the same order. In addition, if there is a loose wire from the timer motor with a slotted contact at the end, make sure you follow the instructions as to where it goes.
Aug 08, 2011 | Bush HD220RWN (6 cu. ft.) Bottom Freezer...
Wont advance cyles, will work if I manually move the dial to the next cycle
Hi, Your timer dial that you are turning is the timer itself which has gone bad. You will need the full model number and go to your nearest repair house to get the replacement timer. Hope this helps.
Jan 17, 2011 | Maytag Washing Machines
My Kitchenaid Superba washing machine won't advance to the next cycle. For instance, it will stay on the wash cycle until you push the dial in and manually move it forward to the next cycle.
ck ing the model # it doesn't work but a washer that the timer will not adv . its just a timer failure . replace timer as it is bad .. you will need a correct mod # of the unit to pur timer .. hope this will help **** ..
Dec 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
STICKS on cycle, wash, etc. If manually moved
Do you mean the timer or control dial sticks. If so then it may be the timer mechanism itself.
Make sure that when you are skipping a turn on the timer that the machine is actually performing that particular task of the cycle. For example if the timer gets stuck before the drain cycle, and you manually skip forward to it, that it actually drains the water out.
If so then it is most likely a worn timer mechanism which sticks.
Ash
Oct 23, 2009 | Frigidaire Dishwashers
Machine will not automatically advance thru cycles
The timer has a motor used to advance it through the cycles. If the machine fills with water and the timer stays in one position no matter where you put it......even in the spin cycle, then replace your timer.
May 03, 2009 | Washing Machines
Washer will not go to rinse or spin cycle
electronic problem in timer board,not being electronically moved to next stage of washing
Jan 24, 2009 | Kenmore 43142 Front Load Washer
HotPoint Top Loader model # WLW1500B
if you hear clicks then I'd have to say it was a mechanical timer. the timer has a small motor on it. a complete timer including its motor will run you about $120 but a replacement timer motor will be about $35.00
Sep 21, 2007 | GE WBSR3140DW Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
